Thats the link i kinda followed and i think the RR results confirm it works to a point, but the engine also uses a little oil, mainly on over-run (on the RR vid you can see ZERO smoke while its under load then when its running down it starts)
The oil consumption is calming down though, as Andyboy has said my bores are 2nd hand so the piston/bore clearance is above standard so this oil burning is not un-expected by me or the guys at the machine shop who carried out the hone.
It's amasing, i leave this thread alone for a day or 2 and it gets interesting
I have let a mate drive it who used to have a E36 328 coupe, he says mine is faster but dosent feel it because its got a much smoother power delivery...... He also cooked my brakes, smoke from the rear pads anyone? so i have parted with more coin and got a set of EBC reds comeing for the front, I was happy with textar but if its ever going to see a track it needs something better.
I'm impressed with the discs though, all that punishment and no warpage...... Brembo = recomended
