arb rear
- **BANNED**
Mounts will be present on the frame of the car,only 'better' E30 came equipped as standard.
I fitted one to my 2.7,which started life as a 3201SE.
Youth is wasted on the young.
M20 wise the 320 didn't have rear arbs, not even SE versions.
The 316s didn't and I believe the 318 was the same except for the Is.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
this is interesting as i own a 1990 320i se and it has a antiroll bar
!! might have being an aftermarket fitment but its well aged to the same exstent as all other parts under the car so it must have being fitted early on in its life
funny someone asked a similar ? on Bimmerforums today ...here is the reply
Here are the various E30 sway bar configurations.
318i (m10): Front: 18mm Rear: none
318is (m42): Front: 20mm Rear: 12mm
318i Convertible (m42): Front: 21mm Rear: 12mm
325e (pre 9/86): Front: 18.5mm Rear: 12mm
325e (9/86): Front: 20mm Rear: 12mm
325i Front: 20mm Rear: 12mm
325is Front: 20mm Rear: 12mm
325i Convertible Front: 21mm Rear: 12mm
325i Convertible M-Tech Front: 21mm Rear: 14.5mm
325ix Front: 17mm Rear: 14.5mm
325ix Touring Front: 18mm Rear: 14.5mm
M3 Front: 19mm (attached to the strut instead of the control arm) Rear: 14.5
__________________
__________________
Well my 89 320i 4dr doesn't have one. I'm guessing those that did hav them were specced with 'm-tech' suspension from the factory? Does anyone have a complete list as above including all variants?
"doughnuts - power braking in circles" Peterborough Evening Telegraph
- **BANNED**
Strange how on DavD's list the 318i convertible has an M42 engine,new one to me,that!
Mine came with an M40,currently sat outside of my garage waiting for it's new home....
You could be right as my 90 build 320iSE didn't have a rear arb.djk wrote:Well my 89 320i 4dr doesn't have one. I'm guessing those that did hav them were specced with 'm-tech' suspension from the factory? Does anyone have a complete list as above including all variants?
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
