i want to change the timing chain on my IS as i dont wont it to snap and want to know it is new and in working condition
also want to advance my inlet cam timing by 6 degrees
has annyone any idea how easy cam advancing is, and how much bmw or other garages will charge me for this??
any advice also?
regards
Help/Info needed & appreciated please - Will bmw rape me
Dan318-is
jmc330i
Sorry, cant help with your questions but I just wanted to say that I preferred the original thread title.
And in answer to that - Yes they probably would, although if you were spending that much money with them, they would probably be nice about it
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Dan318-is
thanks for ya opinion mate!
jmc330i
No worries mate, just my experience - only in the monetary sense ofcourse
Im guessing its all to do with your college project, but how come you want to advance the timing?
James
'91 325i Sport
'91 325i Sport
Dan318-is
college project kinda changed lol, my VW golf blew up, so know gota use IS for everyday car
and got an m20 of jhonno for college project, dunno what im guna do with it after tho
so the IS is jus guna get slightly modded, BBTB Vip.er chip etc
on a timing note, the IS were restricted from the factory in an attemtp to stop them outselling 320is, they decreased throttle sized and restricted cam timing, apprently advancing the inlet by 6 degrees makes then fly
we shall see....
we shall see....
jmc330i
Never knew that. Still, it will give you something to do.....318-is wrote:on a timing note, the IS were restricted from the factory in an attemtp to stop them outselling 320is, they decreased throttle sized and restricted cam timing, apprently advancing the inlet by 6 degrees makes then fly
we shall see....
Shame about the golf though
As for getting the 6pot - you know it makes sense.
James
'91 325i Sport
'91 325i Sport
dazleeds
- old skool raver
when u get to stealers
bend over drop ya jeans
grease yaself up and walk in backwards mate
try find someone else mate cos they will truly invade you
www.oldskoolfantasy.co.uk
keggy
this mite help u on ur quest
This is a compilation of things that are necessary to get real performance out of the M42 engine that you use in a street/auto-x/mild track use car. These are items that will improve the cars performance and not sacrifice any low-end torque, which you want for street driving. These are all pretty much "bolt-on" mods, using the engines factory internals. If you want your 318iS to really fly on the street, these are the things you need to do:
Computer chip - This is a very basic and inexpensive modification for your car. Chips usually run about $200-$300 and are very easy to install. A chip on a stock M42 will bump the horsepower to about 145 (from 135) at the peak. The low-end torque is increased as well to improve everyday drivability. Though the real improvement comes at the top end; the chip widely increases the power band on the M42, from 4600-6000 to 4500-6700. I recommend Jim Conforti chips, as they are unarguably the best on the market for this motor, at a good price as well. On a side note, you will find the M42 makes a very distinctive "howl" from 6700-7200 rpm that reminds you that youÔš're driving an honest-to-God BMW.
Flywheel - A major problem with the M42 was that it had BMWÔš's 'dual-massÔš' flywheel; yes, it weighs almost twice as much as a 325i flywheel (as the name would suggest), at 28.5 pounds. This is a big problem and absolutely kills 1st and 2nd gear acceleration. Ever wondered why your 318iSÔš's 0-60 was so slow? Well, the flywheel is one of the reasons.
There are 3 options to fix this: 1) use a 325i flywheel/clutch or 2) buy an aluminum flywheel for your M42's clutch, and 3) an aluminum flywheel for using the 325i clutch. Buying an aluminum flywheel for the M42 runs about $500-700 but is very light, and requires no modification to be fitted. M42 aluminum flywheels are about 12 pounds, and 325i aluminum fly's are about 8 pounds. The 325i flywheel requires a few other modifications to be fitted in the 318iS. HereÔš's what you need: 325i flywheel, 325i clutch, 325i pressure plate, 325i drive-pinion for the starter motor, and a Ԛâ€Ëa78-Ôš'83 323 throw-out bearing. Replace all these with the 318iS parts and it bolts right together. After all is said and done, your 318iS will have a LOT better acceleration in the first few gears, and deceleration will take place much quicker, which helps on the street and in the auto-x.
Rear end gear - The 318iS is equipped with a 4.10 limited slip from the factory, but you can do better. The desired gears out there are the 4.27 and the 4.45. You will find the 4.27 in E30 318i convertible 5 speedÔš's and the 4.45 is in E36 318i automatics. The 4.45 is a wicked, wicked street gear but will stick your RPM way up there on the highway. The 4.27 is a good compromise of performance and everyday use. It should be known that to make a 4.45 work, you have to swap the gearset into your E30Ôš's differential, or find an automatic 318ti, which has a 4.45 and also has trailing arm rear suspension! So the E36 318ti 4.45 bolts right onto an E30, though finding an automatic 318ti with LSD may be difficult.
Adjust the cam timing - You know how on the E30 M3 you have to buy a $300 kit with adjustable cam sprockets to tune your cam timing? Not on the 318iS! The M42 is equipped with tunable cam sprockets from the factory. So pull your Cosmoline covered valve cover off and with the proper tools you can tweak your intake and exhaust cams up to 6 degrees +/- to provide more top end horsepower or more low end torque. See, you donÔš't have to blow a grand on a set of Schrick cams to make your M42Ôš's cams a little hotter. The best setup is to adjust the intake cam to 5 degrees (advanced) and leave the exhaust cam alone. I would recommend having a shop do this work.
Muffler - The 318iS is equipped with a very free flowing exhaust manifold and center section with 2.25" stainless piping. The bottleneck in the system is the muffler. Thee are a few options for this. The first is a cat-back system, which replaces the piping and boxes behind the catalytic converter. Supersprint makes an excellent cat-back system that runs about $400. You can also simply replace the muffler. There are a variety of mufflers on the market but there is one that is very inexpensive, sounds great (not too loud, but throaty), and fits an E30 very well - it is made by Walker-Dynamax and is called the "Super-Turbo" muffler. It is available from Summit Racing at the price of about $40. We have had great success with these mufflers, and even use them in 3" size on our E30/S50 cars.
Intake system - The 318iS stock airbox works well, but a cone filter setup works better, but only if you have a well-built heatshield! Get a large K&N setup with the AFM adapter and all. Go to Home Depot, buy some Reflectex and build a "cool-air" system by cutting and fitting a heatshield. It is worth it in the end. While you are working on the intake, get the secondary plate of your throttle-body bored out 3mm to 57mm. This will make a difference
Dan318-is
http://www.esatclear.ie/~bpurcell/index.html- superb site!!!
Dan318-is
daz
im breaking it all i need is 200 quid for my MOT tax and 50 quid for OBC n e thing else is bonus lol!
