My 350i and "M3" 356i
HenrikE30
Post Thu Aug 27, 2009 10:52 pm
I posted these pictures in the New members section last week, but what the heck, I'll post them here as well :D
E30s are my neverending love affair and I always keep at least one in stock at all times :P
The only thing I love more than E30s is to attend trackdays with them - that is why my cars are modified for that purpose. My previous "beast" was a "350i" - 1985 323i with a M70B50 (V12 from a 750i - 5.0L 300BHP).
One and a half year ago I started a new project. This time I wanted a no-compromise car that looked pretty much like a standard M3. So, I got my hands on a 1989 320i that was fairly well treated during its life. First I started the work on the driveline - this time engine of my dreams - S70B56. The V12 from the 850CSI. As on the previous car I completely rebuilt the firewall to get the engine as far back as possible. I invested a lot of time and money on quality components for the whole project (I might compile a full list later on). Next up I was turning my attention to the bodywork. EVERYTHING was built from the ground up and before long the new body was in place. The car had become an "M3"
The integral parts are all OEM BMW steel parts, but everything else like doors, bonnet, trunklid and so on are carbon/fibreglass.
Dry weight is about 1150kg.
The car is now more or less finished (will a project EVER be finished? ). When I have had the time and chance to get a proper photoshoot I will post them here.
But, for now, here is a few pictures from the building process:
And finally the only picture I have, for now, that has been taken outside the garage...
All comments are welcome!
eko
Old timer
Post Thu Aug 27, 2009 10:57 pm
Good God,you lucky bastard 8O
Post Thu Aug 27, 2009 10:58 pm
Fooking ell 8)
Post Thu Aug 27, 2009 11:03 pm
Oh my, E30 pooorrnnnnn :drool: :drool:
Post Thu Aug 27, 2009 11:07 pm
That's nice work there, credit to you. :mad: :cool:
E3OBM
Post Thu Aug 27, 2009 11:10 pm
top work fella :D
looking for a 325i cab for a project. why?
GrindCulture
Post Thu Aug 27, 2009 11:12 pm
Wow! :eek:
Not in E30s any more :(
Baz666
Post Thu Aug 27, 2009 11:19 pm
:eek: :eek: lucky bastard to have a garage like that :mad:
ok e30`s are sweet as too :cool:
E30Gheko
Post Thu Aug 27, 2009 11:26 pm
:eek: :eek:
Geeeeezzzeee!! some very nice motors you got there mate! Let's have some more pictures!! winkeye
leeparkes
Weopon 8)
Does it feel nose heavy with the V12 in an E30?
very very nice E30!
HenrikE30
Post Thu Aug 27, 2009 11:39 pm
Thanks for kind words fellas!
Since I have nothing better to do right now I might as well start on that list of modifications:
BODYWORK
A complete rebuild.
The only outer steel panel from the original car is the section where the wipers and VIN is placed
Bonnet, trunklid, rear wing and mirrors are carbon fibre
Doors, rear bumper, front bumper (custom air intakes for brakes and air filters) and side sills are glass fibre
Front splitter made of plywood!! 8)
Wheel arches rolled for wider tires
DRIVELINE
BMW S70B56 engine from 850CSI (slightly tuned - 380+bhp 560+Nm)- Aeromotive fuel system, Catchtank (situated in trunk)
6-speed transmission with oil cooling
Custom driveshaft
Custom built rear diff with oil cooling (radiator, fan and pump is situated in the trunk). Mounted DTM-style with multipoint in the trunk compartment.
Engine, gearbox and diff are all mounted solid to the chassis for - no movement at all 8)
CHASSIS
Everything is rose-jointed and adjusable - no rubber bushes here :D
Custom built DTM-style front and rear. Muzzi Motorsports in Austria has delivered most of the components.
Front and rear suspension are coilovers DTM-style, magnesium. Adjustable everything
Partly seem welded
Undercarriage completely scraped for polyurethane coating (about 18kg less weight) and is now painted the same colour as the car
A COUPLE OF TECHNICAL HIGHLIGHTS
Electrical power steering pump
Electrical water pump with on-board diagnosis coupled with an oversized radiator fan (I select the wanted temp. and the pump and fan always "hunt" for that setting, even when engine is off)
Custom steering rack, 2.2 turns lock-to-lock
Oversized oil cooling system with Earl's components -12 AN hoses.
Custom stainless steel exhaust with active valves
BRAKES
Motorsport 8/4 piston calipers with floating rotors
Steel braided hoses
For the timebeing no ABS (but will be fitted)
Tilton pedal box. Standing pedals. Brake bias adjuster
INTERIOR
Custom carpet with. Only 3.8kg. OEM BMW part. But is only available in Pearl Beige or Blue. Dyed black in my own bath tub :D A dirty job!!!
Rollcage (Due to strict Norwegian law it is unfortunately not a full DTM-style cage)
Carbon details
Sparco seats and 5-point harnesses
Custom Alcantar roof lining
Stack instrument cluster
That is all for now, but the list is MUCH longer, just don't remember everything right now...
Eddie25
Post Thu Aug 27, 2009 11:45 pm
:eek:
Incredible talent. What an E30!
HenrikE30
Post Thu Aug 27, 2009 11:48 pm
leeparkes wrote:Weopon 8)
very very nice E30!
Actually it doesn't, with all fluids in place the cars weighs 1210kg. About 640kg is at the front and the rear has about 570kg. It is of course not perfectly balanced like a standard M3, but because of the advanced suspension and adjustability it is really quite nice to drive. Very predictable and precise.
The engine weighs in fact about the same as an S38 (M5 engine).
That plus the extensive modifications on the firewall lead to relatively ok weight distribution.
It is ever so slightly understeering at turn-in but settles quite nice, if it gets out of line a quick correction with the right pedal is all it needs.
Nath325i
Post Fri Aug 28, 2009 12:23 am
That's one stunning e30 with alot of time and effort put into it :cool:
Pal318is
Post Fri Aug 28, 2009 12:30 am
That's some HEAVY DUTY Moding there Henrik...
The finished article, looks stunning :twisted: It must be an absolute Beast to drive!!
As Tony (eko) said, you lucky bastard :mad: :mad:
Welcome too :)
Pal
Image[img]http://Image
ROC
Post Fri Aug 28, 2009 12:35 am
Just fantastic, I think we would all like to see more pictures of both cars please :thumb:
DRIFTBOY
Post Fri Aug 28, 2009 2:30 am
Yes we would, please! :D
The best E30s, and other cars, come from Norway, I like you guys! 8)
Felix79
All loved up !
Post Fri Aug 28, 2009 3:20 am
holy fuckcakes batman 8O
Felix79 aka Dan
E85 Z4M Roadster
don2009
Post Fri Aug 28, 2009 5:09 am
Nice car mate!
You know the rims that youve got on your m3 are they 3" inches deep (im on about the deep dish part) and are they 16 inch also are they called: BBS 394'S 8.5J ET13 KBA41762
Its just that i was offered simliar alloys to the ones you have on your M3 for my car but i didnt think they would fit.
It would be very helpful if you could answer my question. Thanks
FormerMember
Post Fri Aug 28, 2009 6:21 am
Oh man you crazy Norwegians have way too much money and time! :D
Astonishingly great car, is it road legal?
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
yetti24
Post Fri Aug 28, 2009 8:54 am
what a car , very nice , i bet it goes like stink
HenrikE30
Post Fri Aug 28, 2009 9:29 am
don2009 wrote:Nice car mate!
These wheels are the BMW/BBS wheels that was a factory option for the E32, E34, E38, E39 and E31 (and in fact E36 as well, but not with deep dish design). I think they are called BBS RC009. They are not 16" but 17" and only two-piece not three.
To help you in your question here is my specs: (remember that my arches are rolled and that the front wings on my car are the SE III's with the"18-inch" cut)
Front:
8x17 ET 22
20mm spacers
215/40-17 semislick tires
Rear:
8x17 ET20
10mm spacers
235/40-17 semislick tires
Hope this helps you!
HenrikE30
Post Fri Aug 28, 2009 9:35 am
yetti24 wrote:what a car , very nice , i bet it goes like stink
Well, it is enough to keep up with the traffic :D
In fact it is stupid-fast... Because of a very "agressive" diff ratio the top speed is not more than 258km/h but it gets there very quick.
0-100km/h (0-62mph) is about 4,5sec. But that is starting from 2. gear (first gear is actually pointless with the current diff)!!!
If I start in fourth (not kidding) 0-100km/h is about 9 sec.
Haven't had the chance to test that much yet.
wheelie_lv
Post Fri Aug 28, 2009 9:37 am
that's sick! :twisted:
how do you like toyos R888 on the track?
And...what about the weight distribution - how about cornering with so heavy front?
90' E30 325i 2-door M-Technik 2
HenrikE30
Post Fri Aug 28, 2009 9:51 am
wheelie_lv wrote:that's sick! :twisted:
I have always liked the Toyos for their price/performance ratio. There are probably better trackday tires out there but I like these very much.
On Norway's tight tracks the fronts don't last very long (in particular the left front tire)
Weight distribution is actually relatively good (I wrote something about that in a post here). High cornering speed is no problem :D
kieran325
Post Fri Aug 28, 2009 10:54 am
Stunning 8O 8)
maxfield
Post Fri Aug 28, 2009 11:20 am
Wow!
Falkster
Post Fri Aug 28, 2009 1:18 pm
That is awesome!!! The gurney flap is mahoosive!!!
mattrs
Post Fri Aug 28, 2009 1:32 pm
Great work mate, im very jelous!
appletree
Post Fri Aug 28, 2009 2:07 pm
love the back end of the M3 it looks awsome, bet it sounds amazing 8)
Daf318is
Post Sun Aug 30, 2009 8:31 pm
Fantastic work :cool: more more and more pics please :D
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Post Sun Aug 30, 2009 8:39 pm
Wow that is a masterpiece. Thats a proper M3 conversion with the rear window.
HenrikE30
Post Mon Aug 31, 2009 1:19 pm
appletree wrote:love the back end of the M3 it looks awsome, bet it sounds amazing 8)
Thanks! :D
It does sound good, but compared to the other one which has a different exhaust system it sounds dull.
In a few weeks I'll be starting the work to change the existing exhaust so that it is similar to the 350's. By then it will sound like a Pagani Zonda (no kidding!)
don-king
Post Mon Aug 31, 2009 1:24 pm
looks :cool: ..........
/// KAMI
Post Tue Sep 01, 2009 2:05 pm
looks great fella
THE ULTIMATE DRIVING MACHINE
