My M20 doesn't seem to have a rev limiter, (or the rev counter is reading too high) as it will sail past the 7k redline.
I've read that having 4pot clocks on a 6pot car makes the rev counter read higher, but to my knowledge, they are the original clocks and it shows idle speed at about 1,000 rpm which I presume is normal?
If they are 4 pot clocks, then I have read that changing the coding plug on the back of the clocks will sort the issue, but does anyone else know why the engine will rev past the redline?
Thanks in advance,
Phil
M20 revving past the 7k rpm redline
m_jermyn
Chip
spp320i
+1m_jermyn wrote:Chip
phil540uk
I've tried 2 different ECU's on it with the same thing happening.
Phil
Phil
georob
2 chipped ecu's
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
George
Ant
- Retired Team Member
4 cyl code plug will indicate around 1K idle ( actual is 680 rpms on stock M20B25 ) stock limit is 6.4K on facelift cars too.
codeplug goes in the front lower RHS of the clocks, only the outer surround needs to be removed to swap it out for the correct item.
Email FTW
mattrs
What rpm is safe for a chipped standard m20 b25?
phil540uk
Tried an aftermarket rev counter on before that confirmed the standard rev counter must have a 4 pot coding plug!
I'll try another coding plug which should hopefully cure it!
Thanks for the replies!
Phil
Phil
Ant
no more than 7K max, can show just over on the tacho though before the party pooper chimes in .
M20 will not make power past 6.5K so the rest is useful over rev should you need to hold a gear longer than anticipated, rtaher than upset the car with a mid corner upchange.
Email FTW
phil540uk
It's an 89 model. Is that early or late?
