318IS CRAZY MPG ADVICE PLS
ETERNITY
Sat Aug 08, 2009 8:18 pm
my 318is is givin me 15-20 mpg.
I have recently had a new engine fitted wich is sound and only as 88000 on it(bought from quarry motors).
evolve chip recently installed also
All serviced, new plugs etc, but used the existing old air filter, seems a bit dirty.
The only other fault is that it as a small oil leak (8/9 drops when parked overnight)
any suggestions wid oil leak and mpg
thanks
mattandjazze30
Sat Aug 08, 2009 8:22 pm
my 316 will only do 90 miles on £20!!! :( dont no how many mpg that is tho lol
johnl320
Sat Aug 08, 2009 8:30 pm
Put a new air filter in and the original chip, see how it is then
john
asmith88
Sat Aug 08, 2009 9:14 pm
did you ever get the co done?
1990 brilliant red 318 is
fuzzy
He who sleeps with "Gingers"
Sat Aug 08, 2009 9:20 pm
power wash your engine with the electrics covered so its nice and clean so you can pin point where the oil is dripping from and take it from there.
asmith88
Sat Aug 08, 2009 9:22 pm
mattandjazze30 wrote:my 316 will only do 90 miles on £20!!! :( dont no how many mpg that is tho lol
roughly about 20mpg.. not great :?
Grrrmachine
E30 Zone Wiki / Team Member
Sat Aug 08, 2009 9:23 pm
If not the blue temp, perished fuel hose? It can dribble from the injector rail feed without leaving an obvious trail of drops, but you'll have a strong smell of petrol in the engine bay if you do.
ETERNITY
Sun Aug 09, 2009 12:43 am
was co???
am nt familiar wid dat term :?
is it wort gettin a differant air filter or jus stock, maybe a performance 1 :wink:
Sun Aug 09, 2009 12:47 am
ETERNITY wrote:was co???
Lose the text speak or whatever it is, please! This forum uses standard English.
Doesn't need an aftermarket air filter; the car just needs putting right whatever is wrong with it.
ETERNITY
Sun Aug 09, 2009 12:53 am
was co please?
Sun Aug 09, 2009 1:01 am
Carbon monoxide. There is a potentiometer to adjust its level at idle on the AFM.
Needs to be adjusted with the car connected to a gas analyser.
ETERNITY
Sun Aug 09, 2009 1:09 am
thanks were do i need to go get this checked out
gareth
Sun Aug 09, 2009 2:01 am
ETERNITY wrote:thanks were do i need to go get this checked out
a garage / mot station with a gas analyser. 5 minute job if it's just settings. at least you'll know if it's beyond 'tweaking' and there's a more serious underlying fault
ETERNITY
Sat Aug 15, 2009 4:46 pm
Ok guys I have had my CO checked and its all good and passed.
Wat other things shud i have checked to improve my mpg, because 15-20 mpg on 318is is a joke.
what about tuning.....???
thanks
ETERNITY
Sun Aug 16, 2009 10:57 pm
ANY IDEAS DUDES TO IMPROVE MY MPG
kam-325i
Sun Aug 16, 2009 10:59 pm
have you put the original chip back in ?
ETERNITY
Sun Aug 16, 2009 11:41 pm
noo because i had same problem with the original chip, and drives so much better with chip
Mon Aug 17, 2009 2:12 am
you may have a fuel leak,my IS has an evolve chip with K&N pan filter.
it returns 32.5 mpg avrg .
robbo86
Mon Aug 17, 2009 1:58 pm
ETERNITY wrote:ANY IDEAS DUDES TO IMPROVE MY MPG
Pardon!?
Banjo1981
Mon Aug 17, 2009 2:09 pm
Are you driving like a numpty?
You seem very focused on "tuning" as opposed to finding a cause of your problem. It could simply be a case of you trying to get everywhere at 90?
My car will happily do 30-35 mpg at cruising speeds but when I get a little heavy footed/enthusiastic then this drops right down.
Maybe worth trying to drive smoothly, keeping the revs below 2K as you change up through the gears. See how that does ya.
ETERNITY
Mon Aug 17, 2009 2:56 pm
I HARDLY REDLINING IT AM ALWAYS USING UNDER 2500 REVS, i will test fuel leak and report back
DeeDee
Mon Aug 17, 2009 3:05 pm
If you've just changed the engine, im assuming you have your old unit? If so, then its probably worth swapping over the coolant temp sensor. These can give bad mpg if they're reading incorrectly. Although generally when I have had them fail they usually fail fairly bad making the car unpleasant to drive.
Im still new to e30's but assuming you've got a lambda sensor? That could also make your car run rich.
It may be worth cleaning the hell out of your tail pipe, going for a spin, just normal sensible driving and then seeing how much carbon deposits are left on your pipe. If it's black and sooty then at least you know your engine is burning the fuel rather than leaking it somewhere, or visa versa.
Ziggy
Mon Aug 17, 2009 3:12 pm
How have you calculated the MPG you're getting?
ETERNITY
Mon Aug 17, 2009 4:27 pm
yes i have i get 30 miles of £10. lol
ermmmmmm
Ziggy
Mon Aug 17, 2009 5:07 pm
Ziggy wrote:How have you calculated the MPG you're getting?
Dave_M3
Tue Aug 18, 2009 1:54 am
Are you using shite fuel?
My iS can get anything from 15mpg upto 45 depending on how it's driven or what the quality of the petrol is like.
If I use good fuel, it doesn't really drop under 25 no matter how much of a prick behind the wheel I am :D
ETERNITY
Sun Aug 30, 2009 5:36 am
K GUYS UPDATE
I can smell petrol bigtime after the car is driven
the smell is strong and can be smelt strong inside the car and the mpg is still not right ..
any further advice or suggestions???
anisotropy
Sun Aug 30, 2009 11:42 am
Grrrmachine wrote:If not the blue temp, perished fuel hose? It can dribble from the injector rail feed without leaving an obvious trail of drops, but you'll have a strong smell of petrol in the engine bay if you do.
Have you checked this -I'd say you already have the answer. Other places to check are where the fuel filler pipe joins with the tank, then follow the fuel pipes down the lhs of car and look for rust.
gareth
Sun Aug 30, 2009 11:48 am
as above, sounds like it's leaking.
areas to check are:
in the bay (hoses from the n/s/f inner wing to the engine and each end of the injector rail.
underneath. rear of the tank / filler neck areas and the hoses onto the fuel filter (just in front of the n/s/r wheel) are common suspects. have a drive, chuck it about a bit (to slop the fuel, provoking any leak) and get under there pronto for a look as petrol dries up very fast.
if it leaks more with a full tank, it's almost definately a corroded tank or filler neck
anisotropy
Sun Aug 30, 2009 11:59 am
gareth wrote:the hoses onto the fuel filter (just in front of the n/s/r wheel) are common suspects. have a drive, chuck it about a bit (to slop the fuel, provoking any leak) and get under there pronto for a look as petrol dries up very fast.
If its the injector rail pipes it drips onto the starter and is pretty dangerous. Fuel filter is in engine bay on an IS so one less thing to worry about.
Messenjah
Sun Aug 30, 2009 2:07 pm
ETERNITY wrote:I HARDLY REDLINING IT AM ALWAYS USING UNDER 2500 REVS, i will test fuel leak and report back
thats part of your problem then ...
who uses under 2500 revs ... ever ?? you will be in too high of a gear and be opening the throttle too wide to accelerate to compensate ... wasting fuel......
clearly you arent always keepingit below 2500 revs because thats a ridiculous thing to claim and you are probably caning the car around but if you were it would be a potential cause of bad mpg
Dave_M3
Sun Aug 30, 2009 6:59 pm
An iS driven under 2500 rpm?!?
It would hardly move!!!
They need to be between 3 and 5 to do anything!
