number plate light
telboy
Sun Aug 16, 2009 12:34 am
number plate light keeps flashing on the check panel every time i put the lights on ...but both bulbs are fine..any ideas cheers
**BANNED**
Sun Aug 16, 2009 9:48 am
Takes only a tiny voltage drop to set the telltale off,I have the same issue on one of mine,usualy after crossing a pothole in our wonderful Lincolnshire back roads :D I expect that the light flickers and that's enough.
You could try another pair of bulbs,good quality one's are better,they cause less voltage drop.
Another possible cause is muck and/or corrosion on the connectors.
Youth is wasted on the young.
mrLEE30
Sun Aug 16, 2009 2:00 pm
check the actual holder is not corroded, clean it with seom emery cloth and bend the holder so they grip the bulb better.
telboy
Sun Aug 16, 2009 2:12 pm
cheers fellas will give it a try
hennabm
Sun Aug 16, 2009 2:49 pm
Does sound like an earthing fault - don't forget to clean round the screw holes as the provide the earth.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
telboy
Sun Aug 16, 2009 3:19 pm
turned out to be the plastic lens/holder itself ...it was snapped where it holds the terminal superglued it back works fine now......cheers fellas..................clever things these check panels ..even tells you the plastic has snapped :D winkeye
