Feeler for interest in BTB exhaust/manifold Group Buy
Enter a group buy or look here for zone discounts
MJJ_ZX6RR
Post Thu Jul 30, 2009 4:14 pm
NayC wrote:Great.
Martin, did you find out a rough price for the BTB3 with say, 5 or 10 of us all in?
Providing it does not prove an unforeseen nightmare to route, Joe is happy to do the same group buy price on the BTB3 as he is on the BTB2. The only stipulation is that he needs to make minimum 5 of the exact same manifold. So 5 BTB2s is fine, 5 BTB3s is fine, but not 2 and 3 etc.
Plan is for the BTB3 to fit stock and modified rack cars, so everyone gets what they need with the BTB3.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
Nay
Channel Island Crew
Channel Island Crew
Post Thu Jul 30, 2009 4:37 pm
Well theres enough interest floating around here and probably plenty of interest from people who dont know that it exists yet.
If the rack works with both modified and unmodified racks, then no-one should need a BTB2 anymore? Unless the performance gains etc have a minor drop. But tbh, it would be so negligable if any that no-one apart from the odd one or two people who deem it necessary.
So no price as such yet?
Uni is killing the project.
MJJ_ZX6RR
Post Thu Jul 30, 2009 6:57 pm
NayC wrote:Well theres enough interest floating around here and probably plenty of interest from people who dont know that it exists yet.
Agree that the BTB3 should make the BTB2 redundant. Prices were at the bottom of the first page,
MJJ_ZX6RR wrote: Example prices for the M20 325i manifold and downpipes are £478.26 + VAT. That is a very handy 36% off, and that applies to both the 2 into 1 or the 2 into 2 with X-pipe.
dano0
Post Thu Jul 30, 2009 7:46 pm
well i should have it all fitted saturday and then i just need to get the car to jo @ btb
Dave_M3
Post Thu Jul 30, 2009 7:50 pm
NayC wrote:Great.
I think a locking of this thread will be needed soonish (once its definate). Danny can set up a thread in the technical section or p.m. me or dave (i'm sure he wont mind :D) with questions and I'll see what I can do to help.
Then set up a new group buy thread soon for definate "BTB3" manifolds.
Yep, any problems just give me a shout.
so all in, they'll be just shy of 600 for a manifold with good gains and fit any rack you like :D
If this all works out there'll be another one less reason why I shouldn't go buy a Sport!!!
MJJ_ZX6RR
Post Fri Jul 31, 2009 1:44 pm
dano0 wrote:well i should have it all fitted saturday and then i just need to get the car to jo @ btb
Excellent news. Do give Joe a call first to sort logistics, his contact details are a few posts earlier in the thread.
As an aside, is there a straightforward way to establish what rack is in my car? I had assumed it was OEM E30, but it is very direct and does not seem many turns lock to lock. It also only had a couple of mm clearance to BTB's M30 6 branch. If it is OEM E30, I cannot understand why people would change it.
Martin.
Dave_M3
Post Fri Jul 31, 2009 2:21 pm
Count how many turns it takes from lock to lock.
If it's 4 it's a E30 rack.
If its around 3, it's an E36/46 or Z3 rack
dano0
Post Sat Aug 01, 2009 6:00 pm
Right i have fitted what i think is a e46 pas rack to my car today
i think its an e46 rack as i was told that if it was a e36 rack i would be able to use the original steering joint but would have to use the rear holes in the sub frame
but i had to use the front holes in the sub frame and had to do away with the rubber coupling so now the joint is just bolted together and i have about 5mm clearance between the lower coupling joint and the down pipe
also i had to put the spacers on top of the rack
so what I'm hoping is the way i have fitted it all together is going to be OK for every one wanting a btb3 to me its the simplest way i found to do it so should be easy enough for every one to replicate
please any questions or comments or ideas let me now because this is going to be at btb next week
many thanks danny
Dave_M3
Post Sat Aug 01, 2009 8:49 pm
Sorry, I didn't reply earlier... was busy at a drift event
Yep, that's an E46 rack alright.
That will work fine, little bit of bump-steer from mounting the spacers above the rack alright but it's barely noticeable.
I have my E46 rack mounted the same way in the iS and it's perfect.
When fitting the 6 branch to please everybody, you could possibly pull the bolts from the UJ and just move the rack between front and rear holes, spacer underneath and overheadd to get measurements with the column in it's different locations
dano0
Post Sat Aug 01, 2009 9:29 pm
when i tried to use the rear holes the joint fowled the down pipe and with an e46 rack you cant put the spacers underneath as there's no room between the sump and the rack
ill ask if btb can factor in a bit more space around the uj where the down pipe is now so the rack can sit further back
i think that should make the manifold work with all different variations
Nay
Channel Island Crew
Channel Island Crew
Post Sun Aug 02, 2009 4:01 am
Sounds like its comming on :)
omac
Post Mon Aug 03, 2009 7:53 am
Got wind of this from an aussie forum. I am interested in getting the BTB3, will keep an eye out for the official thread
nm1
Post Mon Aug 03, 2009 12:36 pm
keep er lit i have my money sittin here 2 get 1 as soon as 8)
Nay
Channel Island Crew
Channel Island Crew
Post Mon Aug 03, 2009 4:34 pm
I'm a wee bit skint this month now, due to a bloody accident in my 5er. Hopefully at the end of the month I shall be prepared. I have a piggybank containing a good sum of money (hopefully :roll:) and upon payday nearer the end of the month I should be ok.... I'll also try hold off some pennies from this month too!
e301988325i
Post Mon Aug 03, 2009 7:32 pm
MJJ_ZX6RR wrote:To get us the decent savings, he needs to make a batch of at least 5 identical manifolds. He is really only keen on doing the stainless manifolds as he strongly feels stainless is a much better material to make manifolds from.
Joe is keen on the idea of the M20 with Z3/e36 rack option too, but he needs to see a car first plus he'd need 5 to get those prices.
Martin.
Just noting my interest, in the BTB3 M20 for quick racks.
£478.26 + VAT = £550 sounds good. . .
What are the advantages of 2 into 1, or 2 into 2 with x-pipe, am I missing something here? Will these mate to the standard system or do they require all new backwards to? If so, do BTB reccommend a full system?
Is the group buy getting towards a list for these manifolds??
I said:
e30topless said:
lock the wife in there
dano0
Post Mon Aug 03, 2009 8:01 pm
right spoke to jo at btb today and the car is booked in for the 24th of august
he said it should take a week so im hopeing to have the prototype at pod if any one wants to have a look
hopfully it shoud be bolted to my tech 1 resto if not ill keep it on my tech 1 daily 8) 8)
so if any one got any questions or sugesstions before this goes to btb please let me no by posting on this thread
oakey
Post Mon Aug 03, 2009 9:58 pm
Can anyone confirm that one of these btb3's will fit around a standard manual rack??? Just for me to be sure init
dano0
Post Mon Aug 03, 2009 10:22 pm
I would of thought so but ill ask when i drop it off. it would make sense to build it so it will fit all applications.
Nay
Channel Island Crew
Channel Island Crew
Post Tue Aug 04, 2009 11:22 am
That was the plan, but if its one or the other then may as well be for quick racks. Then have a BTB2 for normal racks and BTB3 for rack upgrades. But one for all applications is the intended product.
Well done Dano0. And in good time, two days before payday :D:D
Kedge
Post Sat Aug 08, 2009 10:54 pm
Hmmmmm, this had got me thinking now. I've already got a BTB2 but i would love to fit a z3 rack as it was so nice to drive when i had one of the iS.
Instagram - Kedge85
raj1980
Post Sat Aug 08, 2009 11:01 pm
what sort of power increase would you get from a system for a m30 335?
kieran325
Post Tue Aug 11, 2009 10:40 pm
I'm interested in a standard 2.5 stainless steel manifold, how much and when can we have one :P
Nay
Channel Island Crew
Channel Island Crew
Post Wed Aug 12, 2009 12:56 pm
kieran325 - I believe Dano0 has his car booked in for 28th august. Within a week from then, we'll know the news. Also, a lot.... hoping (praying) its under £550.
BTW guys... not incredibly clued up in exhausts, but if I get this "btb3" manifold, would a scorpion center section and backbox (for example) be all I need to have a complete exhaust? Basically, is does the btb manifold fit with oem (or aftermarket) parts, or do you have to have a 2 into 1 pipe or btb's center section etc?
I've not really thought about this yet.
BTW, once we have some conformation from Dano0, should we set up a new thread for people who actually want this now?
dano0
Post Wed Aug 12, 2009 5:40 pm
cars booked in for the 24th . I will right down all questions and ask joe and then post them up on the 24th once i get back
please add to the list
Q1 price
Q2 will it fit around a standard steerng rack
Q3 will it fit a standard exhaust system
Dave_M3
Post Wed Aug 12, 2009 8:27 pm
Q1 price
Q4 Will it offer the same performance as the BTB2 winkeye
I haven't got those spacers sent off to you yet as I've been up the walls but will do as soon as I can and you should have them before the 24th :wink:
dano0
Post Thu Aug 13, 2009 9:17 am
cheers dave that will be great :D
Nay
Channel Island Crew
Channel Island Crew
Post Thu Aug 13, 2009 10:50 am
Q1 Price
Q1. Price for 5, 10, 10+ etc. More in, hopefully the cheaper it gets :D
kieran325
Post Thu Aug 13, 2009 11:00 am
NayC wrote: BTW, once we have some conformation from Dano0, should we set up a new thread for people who actually want this now?
That sound's a good idea, I'm 100% in.
Nay
Channel Island Crew
Channel Island Crew
Post Fri Aug 21, 2009 12:52 pm
Any more updates anyone? (Dano0!)
dano0
Post Mon Aug 24, 2009 9:24 am
hi ill be taking the car down to btb today leaving about 1230 so ill ask all the questions that have been posted and ill post up any answers to night when i get home
cheers danny
Nay
Channel Island Crew
Channel Island Crew
Post Mon Aug 24, 2009 1:47 pm
dano0 wrote:hi ill be taking the car down to btb today leaving about 1230 so ill ask all the questions that have been posted and ill post up any answers to night when i get home
cheers danny
:woohoo:
dano0
Post Mon Aug 24, 2009 7:23 pm
answers to some of the questions
Q1 price minimum 5 orders £478.26+vat no more discount for 10 or more orders the price is what it is .
witch i think is fair
Q2 will it fit standard racks this is the plan and the brief i gave Jo but it all depends on space and the routing of the primaries and collectors we will find out soon
Q3 will it fit standard systems Jo has told me yes it will so no worries there
Q4 performance increases there should be no loss of performance increases to the old manifold so about 10 -15 bhp gain i think
Ive told Jo he can have the car for 2 weeks if needed but he said it might only take a week so ill keep every one updated
i must say i cant wait I'm like a kid waiting for christmas :D :D :D
stonesie
Post Mon Aug 24, 2009 7:50 pm
So £550.00 for one of these.... My credit card's looking nervous :D
I might not be in straight away because ive got to get my owings down a bit but im deffinatly on the list.
oakey
Post Mon Aug 24, 2009 8:15 pm
I'm 'down'. Only if it fits with a standard rack also :cool:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Aug 24, 2009 8:27 pm
Id look to upgrade from my alpina 6 branch to one of these, plase can u keep me posted on this??
thanks
Neil
