yeah because I haven't got an Aluminium welderGeoffBob wrote:Very nice Uwe, some great stainless work.
never mind, at least I can tell you for sure it won't fall apart even if I hit a concrete wall
Don't worry Uwe, I did my whole fuel tank from stainless. Despite my whole effort to strip weight from the car I felt that I couldn't take a chance with the fuel tank. In hindsight I should have made an Aluminium tank and fitted a sheet of stainless across its underbelly (with maybe a 25mm thick sheet of medium density PU foam in between) to protect it.UweM3 wrote:yeah because I haven't got an Aluminium welderGeoffBob wrote:Very nice Uwe, some great stainless work.
haha, that would have been funny! The first lot of pictures was taken with my phone, so you can't see a lot of details. There are actually two small tacks on the bolt in the picture. If you ever want to do the same, use M6 bolts and tack in 4 places! My 2 tacks didn't come off, but with a larger screw head and more weld tacks it will pull nicer/flatter.GeoffBob wrote:
Great work on the No.6 header tube BTW. At first glance I thought you had drilled that bolt inThen I read more closely...
sorry but no. I haven't got the proper tools available and it has taken me 2 days already and still not finished cos I have to cut sheet out with an angle grinder and turn pipe connectors from solid bar. I could draw something up and get it laser cut or punched but that would mean 10+ to make it cost effective.buster wrote:Uwe.
I realy could do with a swirl pot do you fancy making me one the same as yours ?
I only made it because I wanted to fit a new pump anyway and the in tank assembly I bought was cheap as well. If the OEM pump assy wouldn't be such kinked design, a straight piece of SS tube would be the ideal solution and fast to make.buster wrote:ok,
ive seen the alli ones but thought yours with the pump in is a good idea.
busy with work for a change......crossie wrote:Hows it coming on Uwe?
James, I used the ice hockey pucks on my S14 engine with the Aluminum arms without any problems for a few years. The guy I have the idea initially from is using pucks since years and never had an issue.jimmybob wrote:My first post! New to the forum.
The build looks really good, like your attention to detail.
Im in the process of doing the same conversion. I like the idea of the ice hockey pucks as engine mounts and am going to do similar. Did you use the original engine mounting arms? Didn't know how the cast ali ones would fair being almost solidly mounted.
Thanks.
James
hmmmm, whats so difficult in plugging an OEM engine loom in?jimmybob wrote:Not exactly a lot of work, in fact less work than getting the OEM ECU wired up with all its extra's. Also it means i can remove all the unnecessary ancillaries. Added to this the obvious gain in HP and extra functionality of the DTA I am sure it will be worth the effort.
Uwe,UweM3 wrote:another S50 swapper posted this graph on S14.net
Quite impressive methinks
