If Dan's ever passing my place, I have one you can borrow. It's really the only option for removing the sump with the engine in the car.jaistanley wrote:i'll have to go it one of those enging lift things that sit between the wings.
Ian.
Assuming these are wiring diagrams, I can helpUweM3 wrote:buster don't want to be a PIA but didn't you want to mail me some diagrams? (...please)
yeas you are rightian332isport wrote:Assuming these are wiring diagrams, I can helpUweM3 wrote:buster don't want to be a PIA but didn't you want to mail me some diagrams? (...please)
Jai, have you changed the diameter of either the slave or master cylinder? A fat master cylinder can easily displace enough fluid (for a short amount of pedal travel) to cause a narrow slave cylinder to fold the spring fingers all the way back. Not good!! For reference, aftermarket pedal sets include an adjuster on the clutch pedal (an adjustable stopper) to control the clutch pedal travel in order to eradicate this problem (since the guy that makes the pedals has no idea what size slave and master cylinder combination you are going to use).jaistanley wrote:Can anyone think of what I have done wrong during assembly? (this sort of thing doesn;t normally happen to me! I usually spend ages getting it right first time and it usually pays off!!!).
buster wrote:Now will James ever finish his ? worlds longest s50 swap !
Just keep telling people its only pink in certain light - like daylight.jmc330i wrote:Nice one JaiKeep at it, its worth it in the end
Not had much time lately mate - Ive moved twice in the last 6 months![]()
Still, the car is all done except for the paint, but I can live with a fast pink car![]()
I will update my threads when Ive sorted through the pics and got regular internet again.
This thought process is already being worked through..GeoffBob wrote:Jai, sorry, this may be a dumb question: Are you running the exact same engine, clutch and gearbox as Dan? In other words, are the two exactly comparable? I'm thinking specifically, what's the leverage of your clutch fork compared to Dans? Same length fork, same pivot point etc. Any chance you screwed in/out the little pivot point/"ball-on-a-bolt" that the fork rides on, on your box (if it has one of these and isn't just part of the casting)?
Sorry if if you have thought of all of this already. I'm just trying to come up with reasons for you not to have to pull the whole engine out, but if your luck is anything like mine...
jaistanley wrote:can anyone suggest a plan of action that doesn't involve petrol and a match?
...and bind the GimpJhonno wrote:We re-seat the slave...
ian332isport wrote:...and bind the GimpJhonno wrote:We re-seat the slave...
Nice one mate, its an amazing feeling isnt itjaistanley wrote:Ladies and Gentlemen...
I HAVE DRIVEN THE SODDING THING!!!
OK, so only enough to go up and down the lane, leaving a nice cheeky set of 11's outside my drive. I'm absolutely stoked.
I had real problems bleeding mine through as well. Someone on here suggested driving the car and getting the ABS to cut in a few times, then go and re-bleed the brakes again. This is what I did on mine and it seems to have worked (although getting the ABS to cut in with a spongy brake pedal wasnt easy - I ended up on grass to get the wheels to lock).Plus I'm having a nightmare bleeding all of the air out of the system. I have fitted a brand new audi master cylinder (£160!!! OUCH, my ring hurts!) but the pedal is still a little soft and the brakes quite grabby. They aren't bedded in yet to be fair though.
Mines still got all the little jobs to do, even after a month or two on the road, its just so much fun to drive I never get round to doing them - its still pink and I dont careThere are still a few little jobs to do to be fair, but projet cars aren't actually ever meant to get finished are they??
