Steering wobble
Do rep's need spigot rings to center them properly to the hub? Could be the problem there, also replica rims are notoriously soft and may have flat spots causing a vibration, hopefully something simple tho. You have double checked your wheel bolts for tightness again since driving it?
Doubtful if it was fine before with the standard rimsdon-king wrote:does the steering go to the side? could be the tracking, wishbone bent.......
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
Yeah, you got a point......... could be something to do with the wheels he has put on?gcs325i wrote:Do rep's need spigot rings to center them properly to the hub? Could be the problem there, also replica rims are notoriously soft and may have flat spots causing a vibration, hopefully something simple tho. You have double checked your wheel bolts for tightness again since driving it?
EThreezero
Are the wheels new or were they someone elses old problem? Was it the tea boy who stuck the shitty sticky weights to your wheels during his halfassed attempt at wheel balancing?? Did one of the aforementioned sticky weights bail as soon as you left the garage???
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
You have done nothing else other than change the wheels?Batesy8 wrote:Also, the steering wheel used to sit pretty straight when driving straight, now it's rotated about 30-40 degrees clockwise
- mattandjazze30
a trailing arm bush could couse the steering wheel to do that any knocking from the rear?
- mattandjazze30
does it go very light at speed?
fuzzy
get them rebalanced for a second opinion,it wouldnt be the first time mine have been wrong but if you done them yourself im sure you did it right. failing that a flat spot on the tyres or a buckled wheel but that would have become obvious when you balanced them. i light impact with a pothole or kerb can also buckle the track rod and it wont be instantly noticeable due to the curved shape of them until you put 2 side by side to compare.a slightly bent rod end might cause it to vibrate more with the bigger lower profile tyres. check all balljoints.
i fitted mine to my van the other week after having them sitting for 18 months unused. a horrendous wobble turned out to be a flat spot created by the weight on the tyre not being rotated for so long which has slowly lessened and went away with use.
this is very helpfull.
ive got some crap plastic hubcentric rings and im having problems going at 40-50mph but after that the steering is ok and im guessing its the hubcentric rings. but will check my local wheel centre for a full check up on the 17" wheels.
fuzzy
my spigot rings are also plastic and were a really tight fit requiring light tapping on with a hammer to get them on. 80grams of balancing weights sounds very excessive. are you sure theyre not buckled or a flat spot on the tyres from heavy skid wear?
the front wishbones are an easy thing to change and are only about £40 from ECP. is it possible to borrow another set of 17's from someone to try to pinpoint if it is the wheels?
Today I put the two with brand new toyos fitted by myself on the front and the older tyres on the rear, this firmed up the steering, and moved the wobble from 40-50 to 60-70mph. Feels better but there is still a slight wobble. I'm going to change the lower arm asap (anyone got one with bushes?) and see what happens. Any long journeys and ill have to put the bbs on. I'm hoping it may be a flat spot that dissappears with use as fuzzy said. If anyone has any comments or opinions then dont hesitate to reply, please!
- don2009
The wobbling might be due the actual alloy it could be faulty, like you said you werent having this problem before with your original alloys. The alloy might be wobbled (if thats the correct term) basically it doesnt run in a straight line. Get the alloy checked out before you start spending money getting any parts changed on it. Hope that helps, good luck with it!
jacko
- Location: Too near Lakeside for comfort, even when in Spain
I had the same trouble a couple of years ago. New alpina reps fitted. Drove away from the garage and as soon as i got onto the main road i just knew I had to turn around and go back again because the car was undrivable due to wobbling at all speeds. After some serious debating the garage changed all four tyres. The problem was no better but i put up with it for a few weeks. Eventually I found all four tyres going randomly flat due to the amount of vibration breaking the seal between the tyre and the rim. I had the wheels indipendantly tested and they were all warped, and the garage where I bought them unfortunately burned down before I could take it further.
Moral of the story, steer clear of Alpina Reps, they just don't work!!!!
And on the eighth day God created........The E30!
Morat
The quickest checl is to stick some standard fitment wheels on for a couple of miles.....if you have some
