any more progress?
I should say soOOO and sorry its taking so long to get the loom info to you i'm just realy busy and abit slack to LOL
Gunni, do you EVER have anything good to say? Time you posted up one or two of your projects so we can find fault with them. Wouldn't want you to have all the fun.Gunni wrote:Turbo would have been so much easier and overall better.
My 2.8 project is in the galleries thread.GeoffBob wrote:Rich, if 7psi (roughly 0.5 bar) boost is all you require to get your desired HP then do exactly as Appletree described above. You shouldn't have any problems on stock internals at 7psi boost.
However, be careful of comparing your work to Ant's 11psi turbo job as a roots pump type supercharger (such as the Eaton) is a lot more inefficient than a turbo and thus puts a lot more heat into the air that it pumps, and the temperature of the inlet air has a marked effect upon the probability of detonation. Thus, if (say for arguments sake) 13psi boost is the limit at the stock compression ratio (without exotic fuels, water injection etc) then you'd likely only make it to say 10psi with a roots pump (assuming the roots pump is geared to make it there). This is also assuming you are comparing systems with identical capacity air cooling (same charge cooler, intercooler etc). Heating of the pumped air is generally a problem with roots pumps, and I agree with Appletree that you should, therefore, do well with your large front mounted intercooler.
Trouble is head gasket failure generaly couples it's self with wanking the headmarch109 wrote:Frankly I'd rather leave the HG stock or at least if not stock the weakest link in the chain, I'd rather be replacing that than something else!
