750I 850I manual gearbox options? brian moooore?
320ise
Post Sat Aug 01, 2009 2:18 pm
the 540i has a getrag s6s 420g and the 850i has a getrag s6s 560g are these interchangable as i have plans to v12 my e34 as somthing different with a v12 howell! i have found the engine for £100! but dont wanna really go down the auto road.
if the above is not going to work is there any american or other makes a similar box was used on that may fit? is i dont have v12 manual money at the min!
gareth
Post Sat Aug 01, 2009 3:01 pm
i've always wanted to build a E34 550i! :D
having had a E32 and E34 sat alongside each other, it looks soooo similar and must be fairly easy... (famous last words!)
320ise
Post Sat Aug 01, 2009 3:04 pm
it all bolts up well aparently but allot of people say its a crap conversion due to weight etc but i just wanna here that v12 noise! you might get allot with the m engines but not that!!!!
320ise
gearbox is the main issue!
Ziggy
Post Sat Aug 01, 2009 3:07 pm
gareth wrote:i've always wanted to build a E34 550i! :D
Same here! I'll never do it, as a 540i would be a better car in all honesty (as well as being rather easier!). Would be ****ing cool though! :cool:
gareth
Post Sat Aug 01, 2009 3:08 pm
the gearbox is what stopped me lobbing a V12 in my last E34.
put a LPG kit on it, leave it as an auto and you'll have a very nice, economical daily bruiser. ideal for towing a track car etc also!
bet you could have a nice one on the road for sub £1k, but automatic.
320ise
Post Sat Aug 01, 2009 3:47 pm
i would not have an auto it would have to be manual do getrag do any other boxes that are compatable? can a box be made to fit? what is the actual problem?
gareth
Post Sat Aug 01, 2009 3:57 pm
afaik, no other gearboxes fit.
i don't know the exact reason, be it bolt pattern or otherwise.
320ise
Post Sat Aug 01, 2009 4:39 pm
brian moooore??? maybe the bmw genius knows he is like an encylopedia for bmw mantainance!
whipsey
Post Sun Aug 16, 2009 12:43 pm
if you decide against the swap i'll have the engine off you mate
e21Jason
Post Sun Aug 16, 2009 1:35 pm
Bmw 850csi box, 2-3k second hand bolts on.
probably cheaper to get a cut and shut bellhousing onto a m60 manual box, or a 265 box
Jason
whipsey
Post Sun Aug 16, 2009 1:44 pm
e21Jason wrote:Bmw 850csi box, 2-3k second hand bolts on.
Jason
do you mean a getrag 265 from an m20? or have i just confused myself :cry:
e21Jason
Post Sun Aug 16, 2009 2:22 pm
265 is the e30m3 e28 535/m5 box with a removable bellhousing easier to modify
Jason
whipsey
Post Sun Aug 16, 2009 8:44 pm
so would an m30 one handle it?
