i have a 1991 cabby with the power hood, which is being a bitch!!
i have noticed the bracket that the motor of the middle unit bolts onto has broken. is this bracket replaceable or is it a complete unit?
cheers
convertible hood motor
Which bracket did you mean is it shown on either of these diagrams
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
this thread might give a little more insight
http://www.e30ic.com/powertop.htm
if it is the motor you can buy a new top half in steel for about £100
but more info needed
thanks for the info. the part that is broken is on the motor that lifts the horse shoe, mounted in the middle of the boot.
its the plale that the motor and drive is mounted to, the plate that springs away when you operate the drive disconnect lever. it is broken at the pivot pin end.
cheers.
cheers.
