water vapor jet
Aron
Post Fri Aug 12, 2005 11:04 am
hi! i've got this bottle from my friend and i'm going to make some experiments on that. do U guys have any idea of this "water vapor jet"?
i've found their website:
http://www.invoauto.co.uk/Products/Wate ... or_jet.htm
they suggested to connect this bottle to the vaccuum hose, say, a by-pass from the vaccuum hose of the fuel pressure regulator to the air inlet. then...
would it be a kind of "air leaking" in between the fuel pressure regulator and the inlet manifold??
any idea?
Aron
E30Adam
Post Fri Aug 12, 2005 3:28 pm
Looks like a load of crap to me.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Aron
Post Fri Aug 12, 2005 3:30 pm
wow!! then a kind of lean burn for the engine also??
jmc330i
Post Fri Aug 12, 2005 3:43 pm
:wtf:
How, What, Why??
James
'91 325i Sport
'93 318i touring 16v
Aron
Post Fri Aug 12, 2005 3:59 pm
well... in detail, i still need to find out but...
according to their suggestion, we need to connect the vaccuum hose to the bottle and hence to "suck" the water vapour. therefore there must be some "extra" air runs into the inlet manifold which is NOT count by the air flow meter and i think this would mess up the calculation of the sensor and a lean burn may appear.
correct me if i'm wrong. Thanks!
rowemeister
:wtf:
mmmmmmmmmmm :bs:
Car will probably go like this once fitted ---> :crutch:
325i Sport with Hartge H27 lump
Aron
Post Fri Aug 12, 2005 4:04 pm
hahahahaha~~ i like that icon!!!
according to my limited knowledge, lean burn is not good for engine in some way.
Widge
Post Fri Aug 12, 2005 4:13 pm
Wter jets have been around for years, mostly on rallying and racing high pressure turbos though, it ceeps the engine cool internally and also burns when the engines get to high temp fuelling the car with more oxygen and hydrogen! Obviously only in small amounts thugh. It usually has a whole water misting or injection system and it's own ecu. I'll try and dig out my book with it in.
spoon320
Post Fri Aug 12, 2005 4:19 pm
Is'nt this some form of water injection? I seem to remember it being bandied about a few years back, mainly for turbo cars.
(bloody brain cells not working - Friday - want to go home... :beer: maybe I'll remember more then!)
spoon320
Post Fri Aug 12, 2005 4:22 pm
Ahh - Found this:
The main function of these systems
is to suppress detonation caused by
high temperature and pressure developed
within the combustion chamber when
the effective compression ratio has
been taken beyond the auto-ignition point
by either a turbo or a supercharger.
Water, with its high latent heat content,
is extremely effective for controlling
not only the onset of detonation but also the
production of oxides of nitrogen in
the modern leanburn engines.
Probably not a good idea in a 20 odd year old design then. :roll:
spoon320
Post Fri Aug 12, 2005 4:23 pm
Ahh - Found this:
Widge
Post Fri Aug 12, 2005 4:30 pm
Spot on info mate
And spot on again!!!!!!!!!!!!!!!
spoon320
Post Fri Aug 12, 2005 4:31 pm
jmc330i
Post Fri Aug 12, 2005 4:35 pm
Yeah, water injection/aqua mist is one thing, but mainly used on Turbo'd cars to keep the inlet air temp at some sort of constant and I think also to reduce the peak combustion temp.
I think Escort Cossies had water injection as standard??
This thing seems to just want to suck some water in :? I cant see how that will help. Surely, if this was to work on a NA engine it would still need some sort ECU management and a way of injecting a fine mist of water.
EDIT - spoon, you beat me to it, nice find 8)
James
'91 325i Sport
Widge
Post Fri Aug 12, 2005 4:37 pm
In which case I think it is B A L L S
Martinaston
Post Fri Aug 12, 2005 5:05 pm
Sounds like a steal at only Ԛ£280 for a plastic bottle :screwy:
There is NO nucleus.
E30Adam
Post Fri Aug 12, 2005 5:09 pm
I've got some hypernitridesuperturbofluxcapacitors for sale at a mere Ԛ£995 each. Guaranteed to give you an extra 100bhp straight out the packet.
TOURINGDADDY
Post Fri Aug 12, 2005 5:12 pm
:lol: :lol: :lol: :lol:
Widge
Post Fri Aug 12, 2005 5:17 pm
E30Adam wrote:I've got some hypernitridesuperturbofluxcapacitors for sale at a mere Ԛ£995 each. Guaranteed to give you an extra 100bhp straight out the packet.
Is that + P&P and VAT?
Adam do you know what thread the sump plugs are? Cheers
Jos
Post Fri Aug 12, 2005 6:28 pm
Also when the water vapour is subjected to that much heat the steam coming off from that increases the amount of gas present in the cylinder creating more power..
Apparently..
Or something...
'94 e36 tree climber
