shadowline trim
armanib
**BANNED**
Sun Jul 26, 2009 8:06 pm
How do you remove the shadowline trim from the door its this bit im on about number 4
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
kevin316i
Sun Jul 26, 2009 8:27 pm
This is a very difficult piece to remove and you will most likely damage it on removal as it is very delicate. It is held on by a series of clips and the best place to start removal is from the bottom gently prising upwards. Use a small timber wedge to help prise the trim off.
armanib
**BANNED**
Sun Jul 26, 2009 8:28 pm
Found out
Trim D is a bit less intuitive. The clips are hidden. Roll the window down and remove the fuzzy inner window gasket (the channel the window slides in) Look inside the void created where the fuzzy inner gasket was. You will see many small clips. Each one with have a rectangular tab sticking out. Push the tab away from the trim with a flathead and it will release the trim. Repeat as many times as needed until the trim comes off.
Bikemanjai
Sun Jul 26, 2009 8:49 pm
Yo wicked, ill get on it tomorrow. Too dark to see in the shed now dude.
E21 318i with an M40 - In a Barn
P38 Rangy - Daily Fuel Guzzler / Trailer Puller
07' VW T5 Transporter Sportline - FOR SALE / Disco 3 Commercial Wanted
52' VW LT35 - Workhorse
53' Sh1troen Dispatch - Spare Van
73' MGB GT
1/4 of an E30 325 Tourer T
armanib
**BANNED**
Sun Jul 26, 2009 9:17 pm
Giv me a text tell me how u got on
