The car has been on a fair old journey! Originally brought about 3 years ago as a bit of a wreck! Heres what it looked like.... not good i know!
I then completely gutted the car to make it as light as possible and did all the necessary repairs to the body before we hit the re-spray stage:
Once we had finished the bodywork we started to pull the rest of the car back together including a roll cage and fitting a Rotrex supercharger so we could stay with the fuel injection.
I then concentrated on getting the engine running nicely with the Rotrex supercharger at about 0.5bar boost with a go-tech pro ECU converstion and 350cc injectors. It Dyno's at 200bhp and 240p/ft of torque at this stage.
I then started on the suspension. It currently has Ian Glass race spec shocks with twin coil spring on the front and stiffer springs on the back, poly-urethane bushes are also fitted.
Following this I fitted a limited slip diff from a bmw 323i and a Wilwood 310mm brake kit with Wilwood 4 pot calipers. It has E36 brakes fitted to the rear as we made the whole car 5 stud and with new wheel bearings all round.
Unfortunately I didn't take too many pictures of the building stage, but do have some of the car at early track events.
And this is what the car looks like today (ready for the track tomorrow!)
Future mods:
New Cylinder head, which im currently waiting to get back from master cams, which should give me a bit more power.
New race seat and new 255/40/17 Bridgeston semi slick tyres for the back.
A Bigger supercharger!!
This is my first ever project and I have tried to make the car the best I can for track use with the limited funds available, but I think it has turned out really well and i'm certainly not finished yet.
[/b]
