One end of the pipe goes to the inlet manifold and the other end goes into I dont know.. and there is a big hole in the pipe..
Could this answer any of my running problems?
Lee
E30's are a little more advanced technically than vacuum advance/retard!anisotropy wrote:I don't really know m20s but is it the vacuum advance? in which case yes is the answer, I'm sure someone who knows more will be along soon.
rix313 wrote:I think the simple answer is there clearly shouldn't be a hole there lol
Or, for a cheapskate fix, just cut 20mm off the damaged end.rix313 wrote:Like the others said, get that hose sorted and see how you get on, ask Cotswolds BMW for a quote,.
doesn't the FPR increase the fuel pressure along with engine load?Brianmoooore wrote:This pipe connects to the fuel pressure regulator, and maintains a constant fuel pressure across the injectors with varying inlet manifold pressure.
Thats what I did after taking the photograph..Brianmoooore wrote:Or, for a cheapskate fix, just cut 20mm off the damaged end.rix313 wrote:Like the others said, get that hose sorted and see how you get on, ask Cotswolds BMW for a quote,.
Was thinking that if holes are starting to develop prob best to change the whole thing for the sake of a couple of £Brianmoooore wrote:Or, for a cheapskate fix, just cut 20mm off the damaged end.rix313 wrote:Like the others said, get that hose sorted and see how you get on, ask Cotswolds BMW for a quote,.
'Course it is, but the "temporary" similar fix I did on the red one in my sig about five years ago is still holding fine!rix313 wrote:Was thinking that if holes are starting to develop prob best to change the whole thing for the sake of a couple of £
that makes senseBrianmoooore wrote:One end of a injector is in the inlet manifold, and the other is connected to the fuel rail. The FPR maintains a constant pressure between these two points.
The FPR increase fuel pressure with reference to external atmospheric pressure, but not across the injector.
