It's time to drop in my S50B30, and somewhere for a while ago, I read something about a spacer on the left engine mount / mounting arm?
How thick should this spacer be? And why do I need it (To clear off what)?
And it's only on the left side? (The cars left side / Inlet side?)
Thank you very much!
Oh, and this is my engine mounts...
https://www.koed.no/functions/billede.a ... .jpg&map=1
And here, from the same shop that sells some M50 / S50 swap parts:
The only problem is that I don't have time to wait for the spacer to arrive if I order it, and I really don't want to pay that much for an aluminum spacer that I can make at work in 10 minutes.
Anyway, from the pics I would guess it's about 10mm thick... what do you think?
