Boot Spoiler too heavy!
Hyperion
I got a IS boot spoiler with a LED (not standard), and its too heavy for the boot, has anyone had this problem, and can it be fixed?
E30Mark
you need the uprated bootlid springs from a mtech II kit car.
Hyperion
phoned BMW dealership and they said they cant help me
maybe a tasteful stick to hold the boot up will be my solution, its abit cheapy but oh well.
E30Mark
This is for a saloon i assume, if so the part numbers for the springs are
41.62.2.238.836 (right hand spring)
41.62.2.238.835 (Left hand spring)
right PIA to fit apparently....
listed as Ԛ£8 each approx.
give the dealers another ring with the above part numbers and see if they can help.
Templ8e30
Have you tried moving the ends of the torsion springs over to the next slots ?.
There are 2 slos for the springs, nn soiler cars use the lower tension position but all spoilered cars (lip or mtec) use the other one just behind it.
Worked fine for my fake mtec before I put the lip back on.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Hyperion
interesting, can you give a little more infor or maybe a pic or two.
Please
Please
rowemeister
You could tie a few Helium balloons to the spoiler.
325i Sport with Hartge H27 lump
Stoney_god
Or just not open the boot.rowemeister wrote:You could tie a few Helium balloons to the spoiler.
dazleeds
- old skool raver
the springs temple means are under the back shelf in the boot look up n you will see em just move em to the other slots and see if the bootlid still hits you in the head (ouch)if it does try again hth Daz
www.oldskoolfantasy.co.uk
keith52
Does work , i've an m tech spoiler fitted along with optional extra inner panel and the settings are the bars are located on the holes nearest the rear of the car
Hyperion
Shit i checked and it looks like it is aleady on that setting. Now that i think about i think it used to keep the boot up before...
it only started bothering me lately. i think i will try to get new boot springs.
thanks
thanks
