Recaro Seats - am I on to a winner?
There was a red touring on here a while ago with RS Turbo Recaros which looked awesome.
Other Recaros from the same era should be able to fit with a little fettling - 2.8 Capri, Opel Manta, Astra GTE should yield some which won't break the bank.
StuBeeDoo
To do it properly isn't that easy.
You'll need to source the Recaro aftermarket subframe adaptors or get someone to fabricate you a set - if you can't weld to MOT standard yourself. Then you'll need to get busy with an angle grinder. After that you'll need to re-stitch the base bolster covers.
...... And if you're 5'11" or taller, don't bother - your head will be wedged against the headlining.
RSTurdo ones can be made to fit on the Ford runners, but doing it that way isn't an option if you're over 5'8".
Sierra Cosworth ones won't fit unless you go the route I described above.
Sierra Cosworth and RS Turbo Recaro seat bases are both quite deep IIRC, whereas the Capri/Manta style ones have much flatter bases so shouldn't cause issues with headroom.
Sierra cosworth recaros and slightly bigger than Escort RS turbo ones and the sierra ones are the closest match in size and shape to E30 ones out of similar shape ones from Capri 3/manta 2/escort 3 and 4/golf 2/rover 800 and 600.
I have Fiesta RS1800 Recaro's one mine. I found it easy to fit them, it took less than 2 hours all in! I had to make up two brackets and get a bit welded but it was nothing too serious. They allow me to sit comfortably and theres lots of head room too.
StuBeeDoo
..... But only in terms of runner spacing. The distance across the bolsters is the same so they take up the same space in the car. The backrests are interchangable on the bases.bss325i wrote:Sierra cosworth recaros and slightly bigger than Escort RS turbo ones
So, what´s the difference between fiesta/escort/sierra Recaros (leaving runners apart)?.
Is there any difference in size, shape, bolsters?. They look the same to me.
Also, what kind of adjusts do they have?.
StuBeeDoo
I've never had a close look at Fiesta Recaros.Torsen wrote:So, what´s the difference between fiesta/escort/sierra Recaros (leaving runners apart)?.
The Escort and Sierra ones have adaptor frames welded to the base frame to enable them to fit to the standard Ford runners. I imagine the same would apply to the Fiesta ones.
