my new cabs tapping a little and been told one of 3 things, so thought id check it out with you lot. Firstly the tappets (or eccentrics) could need adjusting, i seen the link for this so will be doing this soon.
Secondly, could be blowing exhaust manifold, been told sometimes these crack is this right?
And finally, a lad down the local grage said something about injectors? Can anyone enlighten me are these common M20 probs?
cheers
glen
tappety noise from 325i?
TOURINGDADDY
glenbat
cheers touring..
would you replace the eccentrics too? Think theyre about Ԛ£2ish each?
TOURINGDADDY
glenbat
would they be visably worn, or only be able to tell once I've tried adjusting them?
cheers again
cheers again
tourer-dan
With the engine cold, stick your finger in the oil filler hole and feel a cam lobe to see if it's got ridges worn at either side. Very common on cars which have just been bought, as the owner has taken it to have the tappets done (cheap) to be told the camshaft is worn out and needs replacing (expensive), so they sell it telling the new owner it only costs Ԛ£20 to have the tappets adjusted.......
Of course it might just need the tappets adjusting.
I've got a set of injectors if it turns out to be them and you want some, but they are usually very reliable (so I'm told)
let us know how you get on.
glenbat
dan
you a bit of an expert? im looking to borrow someone for half hour to give her the once over
glen
glen
tourer-dan
God no!!!
I've done a couple of Head gaskets on the M20 and know a bit about how they wear their cams. I did my own and reconditioned my own cylinder head.
Just learnt through experience and trial and error.
I'm perfectly capable of looking after my own car and would gladly help with any jobs if I can find the time, but I'm no expert!
glenbat
cheers dan
do you know of anyone local who is a bit of a BM nut? I was hoping to drive to someone in the know and them be able to tell if its eccentrics/cam wear/exhaust blowing just by listening or feeling?
glen
glen
tourer-dan
I'm sure there'll be someone in Harlow, but if you get stuck and you're down this way give me a shout.
