SPEEDOMETER- HELP NEEDED
av3-316i
Post Wed Aug 10, 2005 7:37 pm
:cry: Hi. The speedometer on my 318is was working intermittently from I got the car and then stopped working altogether. I tried replacing the sender and also tried another instrument cluster. The signal from the diff is reaching the dash perfectly so there is no problem with those 2 wires and power is also reaching the speedometer from the fuse. What is left that could be the problem.
cwbprodigy140
Post Tue Sep 20, 2005 1:57 pm
I am having the same problem in my 1989 325i ES :( , and i haven't got clue about how to get it working could someone point us in the right direction? cheers
Post Tue Sep 20, 2005 8:50 pm
av3-316i wrote::cry: Hi. The speedometer on my 318is was working intermittently from I got the car and then stopped working altogether. I tried replacing the sender and also tried another instrument cluster. The signal from the diff is reaching the dash perfectly so there is no problem with those 2 wires and power is also reaching the speedometer from the fuse. What is left that could be the problem.
Not a lot left. What makes you so sure the diff signal is reaching the cluster?
Does the mile counter work on either cluster?
Widge
Post Wed Sep 21, 2005 11:23 am
I have had this on 2 E30's I have had and both times it has been the connection to the diff sensor - it corrodes as it's open to the elements, snip the wire and put some new crimp fittings on and clean the contacts on the diff, fixed it for me! Good luck
Post Wed Sep 21, 2005 8:11 pm
Widge wrote:I have had this on 2 E30's I have had and both times it has been the connection to the diff sensor - it corrodes as it's open to the elements, snip the wire and put some new crimp fittings on and clean the contacts on the diff, fixed it for me! Good luck
OP says the diff signal is reaching the cluster.
Widge
Post Wed Sep 21, 2005 10:41 pm
Thought it might be useful for cwbprodigy140.
Turbo-Brown
Boost Junkie
Post Thu Sep 22, 2005 8:06 am
When mine was doing this, resoldering all the contacts in the cluster cured it.
Turbo-Brown
Boost Junkie
Post Thu Sep 22, 2005 8:07 am
cwbprodigy140
Post Thu Sep 22, 2005 12:19 pm
cheers guys, i think on saturday i will give your ideas a bit of a crack, fingers crossed.
orangecurry
Post Fri Sep 23, 2005 7:54 pm
(copied from other thread for info)
my speedo went intermittent, then died. I fiddled with the cables out of the diff, and it came back... temporarily.
So I went to the scrappy today and found a diff speedo plug and kept as much wire on it as possible.
I then cut out as much wire as possible from my existing cable - from where the wire emerges from the body, connected in the 'new' cable and plug, and the speedo reads 100% of the time. (ok I've only done 10 miles since, but it proves the problem is cable/plug)
The length I removed runs over the rear axle, so might well have worn over time?
