Horrible creeking
jamie325isport
A couple of weeks ago my car started making a horrible creeking noise when steering round right hand corners (hard lock) its a rotational noise if you know what i mean the noise comes from the front left of the car any help on this thank you.
sabrje
Could be the power steering pump. Its about the right place and the fact that it only happens on full lock is a good pointer.
jamie325isport
yeah i thought about that but it seems to be rotational as in as the wheel turns round and it only does it when the steering is a full lock to the right? if it was the pump surely it would to it both ways also you can feel it though the pedals and steering?? at first it thought it could have been down to a combination of my knackered suspension and top mounts but thats all just been replaced including springs ( bilstein ) all round.
A1BMW325iSport
try replacing the fluid ?
japcarkiller
:clin:AAAAAAAAAAAAAAAARRRRRRRRRRRRRGGGGGGGGGHHHHHHHHHHHHHHH. is that a vauxhall
they keep killing my cars
At a guess i would say wheel bearing
jamie325isport
Sh*te wheel bearing!! If i remember right the A.B.S wheel bearing is about Ԛ£80!!
does anyone know of anywhere that does it cheaper? (that wasnt main dealer prices). Cheers
mrLEE30
The wheel bearings will be a standard size probable FAG or SKF can help you, take the sample in they will give you one for a fraction of BMW dealer prices, they are the same i know i worked in a shite bearing factory assembling the things!!!
