Cruise control question
clutch switch and erm an extra.... i think
Brenner5
- Contact:
Thanks,
This is exactly what I needed!!
Installed most of the kit yesterday, just need to figure out whether the switch is a clutch or brake switch..
I put that white switch on myself initially it had another connector which just sent a wire back into it.
320_Fizz_i
The brake input is picked up out of the panel behind the glove box the only switch you need to install is the clutch switch. If you don't have the correct bracket for it (like I didn't) you can simply cable tie it with two strong cable ties to the steering column has worked perfectly for the five years I've had mine installed. Yours looks like it is a clutch switch.
