crank fornt bolt thingy
Widge
Post Mon Aug 08, 2005 7:55 pm
Right trying to strip my engine, and I'm down to undoing the crank front bolt. I don't have an engine stand and every piece of wood I try to wedge in the crank is just getting splintered by the counterweights. The engine has no fly wheel too so I can't do it that way. They must be done up very very tight - any ideas??
lentec
Boost Junkie
Post Mon Aug 08, 2005 8:07 pm
i had a 2 foot of 5mmx25mm steel with two holes drilled so i could bolt it to 2 of the crank bolts and simply locked it against the engine stand!
oh might mention 6foot scafold bar and 3 friends swinging off the end!!!!!!!
chu346
Post Mon Aug 08, 2005 8:11 pm
Take it to a garage and they can do it in a vice or use an air gun.
Widge
Hmmm, I don't want to admit defeat but I may have to wait till I get an engine stand.
chu346
Post Mon Aug 08, 2005 8:14 pm
You do know that you can still take the crank out the engine with the front pulley on and the surrounding bracket.
Widge
Post Mon Aug 08, 2005 8:17 pm
OH REALLY! how the F*ck does that work!
And no there is no way I'm taking it to a garage.
chu346
Post Mon Aug 08, 2005 8:26 pm
Widge wrote:OH REALLY! how the F*ck does that work!
Sorry if i offended you widge, but i don't know what kind of knowledge you have.
I was just trying to help :(
Turbo-Brown
Boost Junkie
Post Mon Aug 08, 2005 8:48 pm
I found that a stick of aluminium about 10mm in diameter and about 150mm long stuck in the crank case so that the webs for cylinders 3 and 4 bear against it, combined with the weight of my dad hanging on a 2 foot breaker bar undid mine :)
Conveniently, my mass and the aforementioned breaker bar produce almost exactly the specified tightening torque when it came to doing it back up again :D
Widge
Post Mon Aug 08, 2005 9:15 pm
Sorry mate - I can do it if a garage can. An the first bit meant, how does it come undone? I didn't think you can get to all the bolts for the front oil seal plate.
Widge
Post Mon Aug 08, 2005 10:01 pm
Wahoooooo done it!!! :D
Used the metal rod in crank method and put the block on it's head then hit a welded up socket wrench with a 14lb sledge and shocked it free!!
Now I assume I need a puller to get the crank sprocket off?
Turbo-Brown
Boost Junkie
Post Tue Aug 09, 2005 2:04 pm
Sprocket should just pull off by hand, use a bit of WD40 and tap it VERY gently with a soft faced hammer :)
Widge
Post Tue Aug 09, 2005 3:10 pm
Haynes manual says use a puller, but there is no where to get the legs in :roll: I think wd40 and tapping th crank bolt with a hammer should vibrate it loose.
Turbo-Brown
Boost Junkie
Post Tue Aug 09, 2005 4:59 pm
Aah, sorry! I was talking about the 2.5's toothed belt pulley :oops:
Widge
Post Tue Aug 09, 2005 5:10 pm
Hmm yeah, can't seem to get the TIMING BELT pulley off the crank, and I don't think my bearing pullers legs will fit between the cover and the pulley.....hmmmm
Widge
Post Tue Aug 09, 2005 5:49 pm
Hmmmmm can't find my bloody bearing puller.......................got a set of torx sockets in the market though, bargin at Ԛ£9.99!
I really don't think when I find it there will be enough room......... :cry:
Widge
Post Tue Aug 09, 2005 6:53 pm
Super duper, I found the pullers but it wouldn't go on, so I had a go with a crooked pull and as I was doing the centre up by hand the pulley slid off!! Must have been the WD40 overnight and the application of a small force in the right direction. WHopee i can have the Eta crank in for measurements tonight!!! :D :cool: :twisted:
