Econometer / engine cough
Grrrmachine
E30 Zone Wiki / Team Member
Sun Jul 05, 2009 5:56 pm
My 320i isn't idling right, and worse, the econometer goes haywire.
Start the car, let it idle, and the econ needle swings all the way over to the right. Then it will start surging, and the needle will swing back to the left.
Once you're out and moving, it takes about three minutes for the engine to "cough" and then the econ needle is out of order completely, never coming back until you shut the engine down and restart, and then it only works for a few seconds.
Any causes? Does the econ get its reading from the TPS, or from the AFM?
dicko
Sun Jul 05, 2009 8:02 pm
I had a similar "cough" with my car , it turned out to be a faulty tps it was on a m50 engine but the econometer did just what you are saying , I would a tps , the econometer gets its signal from the ecu
Grrrmachine
Sun Jul 05, 2009 8:11 pm
Yeah, it was my gut instinct as well, so I just took it off and did the hole-drilling trick, filled it with contact cleaner, blew it out and tested it with a multimeter.
In one position I get 0 ohms across pins 2 and 3, and infinity between 1 and 2. If I move the shaft past the "click", all pins will read infinite resistance, so I guess the whole switch has gone duff.
That'll be fifty quid then :(
dicko
Sun Jul 05, 2009 8:26 pm
I guess so
