When fitting eccentric bushes do I need to change the arb's?
Alburglar
Post Fri Jul 03, 2009 6:04 pm
Hello Folks,
If I fit eccentric (m3 type) poly bushes front and rear do I have to find m3 anti roll bars too or will the standard ones still fit.
Any help appreciated,
Ali
M42 - rightness! with proper 4.27 LSD
JimmyC
Post Fri Jul 03, 2009 6:07 pm
Buy the correct diameter ARB bush for your ARB job done
Alburglar
Post Sat Jul 04, 2009 1:32 am
Ta. Just thought I'd check because I'd heard that when you fit the eccentric bushes and change the cars castor, you need to use the m3 antiroll bar at the rear.
Alburglar
Post Sat Jul 04, 2009 1:34 am
Are there any hidden pitfalls at all? or is it a simple case of buying eccentric bushes for front and rear fit them and go?
Post Sat Jul 04, 2009 1:46 am
Fit and go, but as above, make sure of the sizes for thr ARB's there's 3 sizes iirc
cragles
Post Sat Jul 04, 2009 10:41 am
I think all the pbmwc race cars have the m3 or other eccentric front wishbones bushes, and the series does not allow a rear anti-roll bar - therefore I imagine theres no need to change the rear anti-roll bar!
JimmyC
Post Sun Jul 05, 2009 10:46 am
I think he's talking ARB bushes though craig no control arm ;)
