Best quick shift please
Quaser
Hi Guys
Whats the best quick shift to go for?
1.9 / 2.8 or others?
Part numbers also needed please.
Also - what else do you recommend changing whilst im at it?
Q
Q
Widge
I have the 1.9 one which is a huge improvement on the original. But at some point I'm going to go to the 2.8 or Z3M shifter as I would like it even shorter. If you are unsure go for the 1.9 as then the shift won't be too stiff.
- Z3M Pt No 25112228384
2.8 Pt No 25111222884
1.9 Pt No 25117527252
Ziggy
Fitting the 2.8 tomorrow, so I'll let you know
E30Adam'll have a go & give his opinion too no doubt!
Pal318is
I went for the 1.9 one too....very nice indeed
Pal
[img]http://
[img]http://
Demlotcrew
2.8 not bad, but there is talk of 3.0l X5
A
A
Pal318is
Tell us more?? What do you know??Demlotcrew wrote:2.8 not bad, but there is talk of 3.0l X5![]()
A
Pal
[img]http://
[img]http://
Quaser
so any updates on the 2.8 one then?
Q
Q
Geeman
Do the 2.8 lever upgrade... it's great!
Widge
Hmmmm.....anyone want to buy my 1.9 lever so I can upgrade to a 2.8 one??? It's only got 3000 miles on it!
Ziggy
2.8 it is!!
Adam's got pics comparing em & we've both driven mine on the 2.8 & his with the 1.9... 2.8's significantly shorter, but requires a li'l more effort like you'd expect. Suffice to say he's probably gonna upgrade
p.s: Thanks again Adam!
E30Adam
I'll start a new thread with the pics.
I think I'm even going to alter the tech article.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Geeman
Can you include pics of the Z3M lever as well...?
Although I found the 2.8 a little 'notchy' to start off with, the shift action was superb. Made me think about going a little further and doing the Z3M lever upgrade to the track car...
E30Adam
I didn't have a ZM lever to hand to photograph mate.Geeman wrote:Can you include pics of the Z3M lever as well...?
Here's the thread with the writeup
http://www.e30zone.co.uk/modules.php?na ... 966#152966
M5pilot
Best one is made by UUC.
E30Adam
And best for the money?M5pilot wrote:Best one is made by UUC.
Can't beat an OEM swap if you ask me.
All they do is increase the pivot point in the gear lever. There's nothing magical in doing that so I fail to see how a different make could be any differnt apart from different percentage throw reductions.
Widge
And percentage effort input increase??????????
GDBN
How come the part no. given here "1.9 Pt No 25117527252" is different from that given under the "articles" section for a short shift 2511 1 434 148 ??
Thought they were both a Z3 1.9 upgrade ??
G
G
Widge
Probably because I have given the wrong one I got off the OEM.
rowemeister
I had my left arm broken and shortened!!
This seemed to work a treat
I fitted the e36 M3 shifter which I think is the same as the 2.8 Z3.
325i Sport with Hartge H27 lump
