worn subframe bushes symptoms?
cro320
What are the common symptoms of worn and failed main rear subframe bushes?
pac1982
Your back end will feel loose almost like the back end is stepping out bumps will also feel more harsh and travel through the car with lots of judder
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
toby
Feels like you have a side wind on the motorway even when there isn't one.
Will it make the car feel more bouncy?
toby
Not as much as worn rear dampers would. Worn subframe bushes don't really bounce but if they are really bad there may be extra momentum in the bouncing of the rear of the car and it would not feel as tight as it should.
cro320
mine makes thump thump noise on one side over bumps, it's also a little unstable at higher speeds, also on revy start I feel like my rear end moves...
Sounds like we both have the same problem
pac1982
You sure the knocking sound ain't your exhaust?
cro320
nope, I already sorted thatpac1982 wrote:You sure the knocking sound ain't your exhaust?
stonesie
Have you checked the rear top mounts? they like to make a bit of a racket when they fail.
cro320
as I said once before, car is maintained regulary, I never drive even a day with something clunking or loose under it, so I changed everything except rear axle bushes last month...stonesie wrote:Have you checked the rear top mounts? they like to make a bit of a racket when they fail.
now car is quiet but when driving in rain I can hear some tump tump noise when cornering, adding/releasing power and car feels a little unstable in the rear
Bally
another symptom is it will fail the MOT (reason why i am changing mine on 318).......
