3 52mm Aux Gauge Pod - Ashtray Mount.
Enter a group buy or look here for zone discounts
Kedge
Post Tue May 19, 2009 9:30 pm
Hi folks.
I'm looking into getting some mounts made up for mounting 52mm auxillary gauges where the ashtray sits. These are the same ones from Kos' group buy a couple fo years ago.
The only pic i have of one at the moment is from searching the zone as mine is currently away at the fabricators for them to assess and give me a price to get some made.
These will be made from either 1mm or 2mm thick metal and will come unpainted so you can add the finish you want yourselves.
I haven't been given any clue as to how much these are going to cost but i'm sure the more people i can get to make an order will help to bring the price down, i do remeber paying somewhere in the region of £35 inc P&P when Kos ran the group buy.
Anyone interested can you add your names to this list please;
1.
2.
3.
4.
5.
Instagram - Kedge85
tari
Post Thu Jun 04, 2009 10:19 am
Where can you get these gauges from? I need mainly just the voltage one..
pac1982
Post Thu Jun 04, 2009 10:22 am
I'm after the same sort of thing but instead of replacing the ash tray i want them in the recess just behind the ash tray, i think you used to be able to get an OE part for this but not sure if its still avaible?
Post Thu Jun 04, 2009 10:44 am
like this.
pac1982
Post Thu Jun 04, 2009 10:54 am
Ai just like that, dont suppose you know if you can still get these or if you have the part number so i can check with cotswold in the OE parts section?
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
baur320
Post Thu Jun 04, 2009 10:56 am
magpie wrote:like this.
I like that
Current E30 325i, E63 630is.
Post Thu Jun 04, 2009 11:18 am
it's Iains [HartgeH27]
DaveD
E30Zone Wiki Specialist
Post Thu Jun 04, 2009 12:23 pm
tari wrote:Where can you get these gauges from? I need mainly just the voltage one..
These are what has been used before ..it has never been an oem part as far as I know the one above is a Hartge one
http://cgi.ebay.co.uk/Audi-coupe-VW-Gol ... 1|294%3A50
some previous threads
http://www.e30zone.net/modules.php?name ... vdo+gauges
and best of all
http://www.cscoupe.org/tech/gauges/gauges.html
tari
Post Thu Jun 11, 2009 10:43 pm
cheers DaveD
DRIFTBOY
Post Sun Jun 14, 2009 3:33 am
You can cut holes straight into the console trim, there is enough room behind it for guages, you don't lose the ashtray or little storage bin in front of it and you can see them fairly well from the drivers' seat!
Just a suggestion. :)
Here's mine:
Benho
Post Sun Jun 14, 2009 12:25 pm
drift boy, that is sweet!
DRIFTBOY
Post Sun Jun 14, 2009 1:51 pm
Thanks! :)
Not that difficult to do either, just measure and mark out the holes centrally on the foam back of the console with pencil and then cut out with a Stanley knife!
tari
Post Sun Jun 14, 2009 10:25 pm
Driftboy, Thats exactly what I want to do. What guages did you use for that?
Tee
DRIFTBOY
Post Sun Jun 14, 2009 10:37 pm
I'm not sure from which model (I bought them from another 'Zoner) but they are out of a late 1980s / early 1990s Audi.
tari
Post Sun Jun 14, 2009 10:40 pm
Oh.. and they came out off the housing with no problems? I thought they were one piece din sized units
Tee
DRIFTBOY
Post Sun Jun 14, 2009 10:44 pm
They are fixed into a metal mounting bracket, but the front trim (from the Audi dashboard) can be removed, if you see what I mean.
The second photo shows the mounting bracket.
tari
Post Sun Jun 14, 2009 10:58 pm
Yea, I get what you mean.. Thanks mate, I appreciate your help, I'm going to get right on this.
Nay
Channel Island Crew
Channel Island Crew
Post Mon Jun 15, 2009 6:26 pm
Looks good, but what do the meters actually tell you. Never seen them before in an E30. Obviously I have seen things like that relating to turbo pressure, temp etc in boosted cars.
Uni is killing the project.
DRIFTBOY
Post Tue Jun 16, 2009 1:42 am
The Audi guages I have are; volt meter ( :? not really necessary in my opinion), oil pressure and oil temperature, which I find are nice to have. :)
The (rather nasty!) boost guage is next to the stereo! :)
tari
Post Tue Jun 16, 2009 10:42 am
I need the voltmeter as I'm looking to install a PC into my car, on top off my already power heavy sound system.
The others aren't really that important to me.. but then again I don't really know what they do exactly?
Nay
Channel Island Crew
Channel Island Crew
Post Tue Jun 16, 2009 12:19 pm
Ha, where do you plan on fitting a pc into your E30? Quite limited space. Then again I've thought about it too. All I could come up with was either in the boot, or a laptop "plug-in" section that links to a mini keyboard/mouse setup and a small 11" screen or something... (or a screen that comes with those in-car dvd players (which in our cars often get stuck becuase of the indicator...)
maf260
Post Tue Jun 16, 2009 12:37 pm
Here's another option for fitting aux gauges in the cubby hole behind the ashtray:
http://cgi.ebay.com/ebaymotors/BMW-E30- ... 240%3A1318
I've just bought an induction kit heatshield from him to go with a K&N cone filter. Looks like a good, well-developed piece of kit - made from ABS plastic so won't suffer/cause heat soak like the metal versions. I'll post initial thoughts and results when it arrives.
baur320
Post Tue Jun 16, 2009 1:29 pm
I asked him ages ago if he did a RHD version (as I guess his LHD was a mirror image) but he didn't reply.......
tari
Post Sat Jun 20, 2009 3:05 pm
NayC wrote:Ha, where do you plan on fitting a pc into your E30? Quite limited space. Then again I've thought about it too. All I could come up with was either in the boot, or a laptop "plug-in" section that links to a mini keyboard/mouse setup and a small 11" screen or something... (or a screen that comes with those in-car dvd players (which in our cars often get stuck becuase of the indicator...)
I have a heavy duty shock proof, etc. Laptop which I'm going to connect to a 7" touchscreen panel fitted somewhere in my car (Not sure where yet).
The laptop I will place in the boot, and I will be fitting USB ports in the dash for easy up/downloading..
Once I've got everything together I will be doing a build thread on it..
Post Sat Jun 20, 2009 3:50 pm
^^ Look forward to seeing it, something i'd like to do as well :wink: :cool:
