Cloudy windows
f4stjay
I'm having trouble with the driver's window and rear screen on my 1990 325. The glass appears cloudy and I'm not sure what to do to remedy it...It looks like a greasy film that will disappear when wiped with a wet cloth but soon reappears.
I've tried shampoo and water, wax, even as far as some cutting compounds to remove it all to no avail.
Anyone got any miracle solutions?!
J
J
mattsbmw
That sounds very odd, maybe post a pic if you can?
f4stjay
I'll try and get one up for you to have a butchers at...
J
J
'90 325i Sport
JimMW
Perhaps try something along the lines of nail varnish remover of methylated spirits. They are both really good at removing oils tars and waxes from surfaces when water wont budge them, just thinking laterally
f4stjay
I'll give them a try, see if it helps.
J
J
'90 325i Sport
f4stjay
This is the problem I have with the windows...any clearer?
J
'90 325i Sport
m_jermyn
Looks like overspray maybe.... Get a flat razor blade and run it down the glass. When you rub the glass with your hands inside and outside how does it feel? Rough or real smooth?
Might want to try some thinners.. Honestly its very hard to tell but glass should stay transparent forever.
f4stjay
That's the annoying part...
It's definately not overspray, the glass is silky smooth with no rough patches at all. Water makes the window clear for a short time but then it returns to being cloudy. It's definately on the outside as water has no effect if you rub the inside of the window with it.
Going to have to try thinners next I think.
J
J
'90 325i Sport
m_jermyn
If water is making it clear again this suggests that it has scratches in the glass. I suspect water is filling the scratches and thus making it clear again until it evaporates.
Mike
Mike
f4stjay
Thanks Mike, I'll give thinners a go but if that doesn't work it'll be new glass time when I change the electric window motors that don't currently work...
The joys of E30 ownership!
J
J
'90 325i Sport
m_jermyn
old cars are character building are they not?
f4stjay
You could say that
'90 325i Sport
grantfk10
- E30 Zone Meets/Events Team
A long shot , but have you tried Autoglym SRP?
It cleaered my rear (plastic) screen in the cabby.
f4stjay
Finally!!!! It has come off!
- T-cut didn't work.
- Vinegar (suggested from a friend) didn't work.
- Cellulose thinners didn't work.
- Glass wax/polish didn't work.
- Meths didn't work.
- Wire wool didn't work.
Machine glaze and a buffer did the job though
J
J
'90 325i Sport
