My new project cabbie arrived this afternoon
Just poking around it,I noticed that the rear 'battery box' is filled with a huge ballast wieght,anyone know why?
Thanks,thought that throwing it out may make it faster....photobucket are playing me up,or more likely my computer is arsing about,I am unable to copy links for photos at the moment!Rav335uk wrote:It's a vibration damper, and to balance the rear up too.
Only remove this if your going to replace it with a battery in boot mod.
Wheres the pics???
In a few words,Lee,it is to re-shell the 2.7....E30BeemerLad wrote:What's the plans for this one Malcolm, you dark horse
gareth wrote:i believe it's actually a harmonic damper.
i have also read that some later BMW cab's used a special battery that doubled up as the harmonic damper
if this is the case, i guess it should be sprung / damped? unless it just alters the resonant frequency of the shell, which is in essence a spring with a mass, so likes to resonate
looking gooddaimlerman wrote:
Proud new 'owner'....
Steve,if you saw this in Lincoln yesterday it was on a trailer!gareth wrote:a fine looking beastie indeed![]()
some centre caps and a lip spolier jobbie and it'll look a lot tider. i gues those could be 'borrowed' from another car in your fleet?!!!
are those rear arches going?
unfortunately notRav335uk wrote:Mick, do you know if the 15" e34 bbs caps will fit as i have four here, if you're after them that is??
Nice looker there btw
