chip install
chrisE318is
Tue May 19, 2009 9:02 pm
im about to put a chip in my car. just wondered if i need to do anything when i start up for the first time. i.e raised idle, specific things to do upon test drive etc
Kemlo
Tue May 19, 2009 9:07 pm
It'll run rough for a bit, just steady away until it sorts itself out. Took about 30 mins for mine to settle down iirc. 325 switchable auto with a mild chip.
DHFiS
Tue May 19, 2009 10:06 pm
Who is your chip from and is it in a 318iS?
mhuk
Tue May 19, 2009 10:12 pm
Kemlo,
Notice much after the install?
I still to install my speedtouch chip.
marts
Triumph Spitfire MKIV
BMW E30 325i 4dr rightness
SUbaru Justy Gen2 AWD
Tue May 19, 2009 11:17 pm
don't get any static charge on it.
Kemlo
Tue May 19, 2009 11:57 pm
mhuk - not a great deal of performance difference, it revs a bit higher under load and it's smoothed out the power delivery which was what I was after.
It's not a speedtouch chip though (he didn't have one for my ecu at the time - I have heard good things about them however) - got it from Ebay - quite cheap so pretty happy with it.
chrisE318is
Wed May 20, 2009 6:14 pm
looking at a few at the min want one with a good performance increase and yes its for a 318is.
magpie ive read a few posts and i no youve got one, did it give you good gains and where did you get it from?
DHFiS
Wed May 20, 2009 7:02 pm
Mines got the Evolve chip which was only £50 but might be more now. It feels like it makes a small difference to power and it removes the rev limiter.
Wed May 20, 2009 7:09 pm
Chris, follow the E30 Zone Wiki Chip Fitting Guide advice, i.e., let it idle for at least 10 minutes on installation, then switch off, prior to going for a drive - this ensures that the base idle settings are learnt.
Wed May 20, 2009 8:39 pm
chip is easy to fit, opening the ecu is a pain in the arse :mad:
ive chipped mine and it made a big noticable difference, no rev limit, drives better in the lower revs, quicker accelaration well worth it on an IS
where did you get yours from ? :)
bdx
Wed May 20, 2009 8:55 pm
What chip are you running?
Wed May 20, 2009 8:57 pm
bdx
Wed May 20, 2009 9:05 pm
What mileage have you covered since chipping, is their a severe drop in mpg (probably hard to judge) and any engine problems.
18-20bhp seems quite a lot
djk
Wed May 20, 2009 9:10 pm
18-20bhp :wink: Riiiiiiiight-o.
Wed May 20, 2009 9:11 pm
bdx wrote:What mileage have you covered since chipping, is their a severe drop in mpg (probably hard to judge) and any engine problems.
18-20 bhp could be throught the rev range but i doubt it, they all exagerate on ebay, although the chip works really well
had it running with the chip for at least 6-7 weeks now, much better than standard, seemed to give better low down torque too
i would deffinitly buy another :cool:
Wed May 20, 2009 9:13 pm
i was going to do a before and after run on the dyno but i thought it was not worth the hastle, prehaps i will get it done as is next time it gets serviced :)
chrisE318is
Thu May 21, 2009 10:09 pm
i think the chip im going to buy is the £30 off ebay. its got an ecu number on it which matches up to mine
Thu May 21, 2009 10:28 pm
chrisE318is wrote:i think the chip im going to buy is the £30 off ebay. its got an ecu number on it which matches up to mine
i would be wary with the IS ones though, i took a chance
there are 3 different firmware versions and if its the wrong firmware it will idle like a dog :)
chrisE318is
Thu May 21, 2009 10:56 pm
ok thanks think im guna take the chance anyway can only hope for the best. mite see a chip come up for sale soon
Thu May 21, 2009 11:01 pm
:cool: let us know how it goes, took just over a week for mine to get here
chrisE318is
Fri May 29, 2009 8:36 pm
put my chip in today not ran it much but powerwise i can feel a little increase not really given it much yet. not put it against anything yet. it runs ok. got no limiter. but runs rough at idle for around 15-30 secs when cold? is there a period for the ecu to learn the chip if so how long does it take and is the performance gains very noticeable or mild. (£30 chip off ebay)
breaking 2 door dolphin grey tec 2
pm me
djk
Fri May 29, 2009 9:28 pm
chrisE318is wrote:put my chip in today not ran it much but powerwise i can feel a little increase not really given it much yet. not put it against anything yet. it runs ok. got no limiter. but runs rough at idle for around 15-30 secs when cold? is there a period for the ecu to learn the chip if so how long does it take and is the performance gains very noticeable or mild. (£30 chip off ebay)
Speedtouch wrote:Chris, follow the E30 Zone Wiki Chip Fitting Guide advice, i.e., let it idle for at least 10 minutes on installation, then switch off, prior to going for a drive - this ensures that the base idle settings are learnt.
:wink:
Fri May 29, 2009 10:50 pm
mine idle'd perfect as soon as i fitted mine, no rough idle at all
power was very noticable at WOT with mine, also better low down torque it would seem :)
chrisE318is
Sat May 30, 2009 12:08 am
i didnt do the idle start on mine is there anyway i can do this again i.e take the chip out and start again or can i do this by simply starting the car and letting it tick over?
pm me
Sat May 30, 2009 12:09 am
is yours ideling like a bag of nails ???
Sat May 30, 2009 12:12 am
chrisE318is wrote:i didnt do the idle start on mine is there anyway i can do this again i.e take the chip out and start again or can i do this by simply starting the car and letting it tick over?
Disconnect the battery or ECU plug for at least half an hour to reset it, then go through the bedding-in procedure.
chrisE318is
Sat May 30, 2009 2:15 am
yep but it is alot quicker and drive ok just bad idle when cold for 15-30 seconds
pm me
chrisE318is
Mon Jun 01, 2009 9:50 pm
ok ive had my chip in over the weekend and its just got worse and worse on idle so im going to need another does anyone know who will provide the right one for my car if i give them the ecu and chip number. sure i read evolve do it but cant find a way of finding out.
pm me
djk
Tue Jun 02, 2009 12:03 am
Did you try disconnecting the ecu and leaving it to idle? Have you also tried substituting the original chip to see if the symptoms have occurred coincidentally?
Tue Jun 02, 2009 8:09 am
chrisE318is wrote:ok ive had my chip in over the weekend and its just got worse and worse on idle so im going to need another does anyone know who will provide the right one for my car if i give them the ecu and chip number. sure i read evolve do it but cant find a way of finding out.
Evolve certainly used to stock them. Contact details are on their website http://www.evolveyourcar.com/default.asp
Alternatively, try e-mailing Ant at A-Tech.
chrisE318is
Tue Jun 02, 2009 7:04 pm
djk wrote:Did you try disconnecting the ecu and leaving it to idle? Have you also tried substituting the original chip to see if the symptoms have occurred coincidentally?
yer ive tried resetting the ecu and have gone back to my original chip as it was just getting worse but its fine now so must be the chip
pm me
