brake wear sensor light
sheehan879
Fri May 29, 2009 12:27 pm
It still comes on randomly after the discs pads and sensors were changed. Is there a way of determing which one is failing, shorting cables or something.
cheers
Fri May 29, 2009 1:59 pm
The problem is most likely in the instrument cluster.
Use the forum search function to look for "220 ohm" and my username.
dom-1984-320i
Fri May 29, 2009 2:03 pm
I used Brian's advice on this subject last week end, job done and no more problems with random blinking light. :D
