Quick track rod end query.
tomstickland
Fri May 29, 2009 2:21 am
Am I right in assuming that to remove the rod end you loosen the nut and then the whole rod end should unscrew from the shaft that sticks out of the end of the rack?
Dave_M3
Fri May 29, 2009 3:10 am
Yep. Can be quite stiff though...
tomstickland
Sat May 30, 2009 1:32 pm
OK, thanks.
mt1104
Sat May 30, 2009 4:43 pm
my z3 rack required a blow torch to get the ends off.
BMW 318 2dr Atlantis blue road rally car
