Lip Spoiler clips.
How do you remove the clips from the front valance that hold on the lip spoiler or whatever you call it. I cant see properly if I can squeeze the plastic rivet to remove them. Is it a case of extreme force and hope it doesn't snap?
smithy318i
use a screwdriver and a hammer to tap the pins through the retaining clip (upward). don't hit it too hard or you will loose the pins somewhere on the ground and never find them again.
