Didnt take to long to do, got most of the crap off with sand paper and a wire brush. 2 coats seemed more than enough, just got to do the rear drums when i get the car back from the bodysop.
Before
After
Adam
Adam318i wrote:One step at a time, just got my car back from the body shop!!! YAY.
Check E30 chat for the pics of the fineshed job.
Parts will be going on over the next week or two.
Adam
Does it state a temp on the tin thats it can handle? The calipers I quess will get quite hot!Adam318i wrote:It better be![]()
Doing the rocker cover in black hammerite aswell![]()
Adam
Did you use the smooth or hammered finish?johnono wrote:hamerite on my front calipers at the mo, didnt even clean the that well, just painted em up in black... still on there, no chips. a blast with the jet wash and thyԚ´re spotless again
Razza wrote:Are the calipers easy to take off and put back on again, was thinking of doing mine silver whilst they are still on the car....is this a no no!
i used smooth, but i never cleaned the surface that well so it doesnt relly matterProject_E30 wrote:Did you use the smooth or hammered finish?johnono wrote:hamerite on my front calipers at the mo, didnt even clean the that well, just painted em up in black... still on there, no chips. a blast with the jet wash and thyԚ´re spotless again
Do you have any pics?
Adam, you know 325i rear end setup is the way to go mate!Adam318i wrote: just got to do the rear drums when i get the car back from the bodyshop.
