T3 turbo hotside a/r .48 internal wastegate
30lb injectors
large volvo intercooler
Megasquirt V3 extra
Innovate LC-1
Running 6.5 psi
New Turbo
I never said it didn't! I think this goes without saying due to the change in density of the inducted air with boost, and thus the commensurate change in burn time of the air/fuel mix which is density dependent.The optimum advance changes as the boost changes.
Gunni, are you agreeing or disagreeing, with me? Make up your mind. I never said don't run the highest boost possible, I said don't run with detonation. And if you have to significantly retard the timing in order to run the higher boost, then all you'll achieve is higher boost, not more power.So closest to optimum timing would be as close to knock as possible.
So the goal is to design the system for the power level and not boost level.
I never said anything about increasing the advance. What I said was, find the optimum for the given level of boost that doesn't result in detonation! However, I stand by the fact that the only way to tell whether an increase in advance at a lower level of boost will result in an increase in wheel torque is on a dyno. And for the record, I don't own a dyno and I'm not trying to sell dyno time to anyone.People always get hung up on raising the advance and raising the advance
Finding the optimum advance,GeoffBob wrote: I never said anything about increasing the advance. What I said was, find the optimum for the given level of boost that doesn't result in detonation! However, I stand by the fact that the only way to tell whether an increase in advance at a lower level of boost will result in an increase in wheel torque is on a dyno. And for the record, I don't own a dyno and I'm not trying to sell dyno time to anyone.
Thank you kindly sir, that's all I was trying to say. The rest I think we are in agreement upon, bar one minor point, and that is the meaning of the word "optimum".Of course lower boost and optimum timing is BEST.
Thus optimum timing can always be achieved. Ideal timing, however, cannot.Finding the optimum advance, you make that sounds like most engines are capable of reaching that advance. Well they are almost ALL not
I am in 100% agreement with you.Most people lack the ability to tune for scenarios where there are changes that occur, such as the need to retard timing as air temps go up. This mean that a good solid 3rd gear run is mapped fine, but a long 5th gear run get´s higher temps and detonation.
