difference between 320 lump and 325
slideways
Post Mon Aug 01, 2005 7:45 pm
now for all ye smart arses 500ccs wont do
a lad is trying to sell me a "sport" cheapo. says its down as a 320 on the log book but that it has a 2.5
what chassis no identifies a sport/325
looking at the engine is there an easy way to know the difference
thanx all!
dazleeds
old skool raver
old skool raver
Post Mon Aug 01, 2005 7:49 pm
oil cooler is 1 sign look at front behind valancecheck ecu under panal above ya knees
if its a 325 it should be 173 320 is 172 hth Daz
www.oldskoolfantasy.co.uk
Skar
Post Mon Aug 01, 2005 8:17 pm
yes the oil cooler is a good sign, you might want to check the ecu part number and the AFM part number. Or find the VIN number and go to this site and follow the instructions
http://www.realoem.com/bmw/select.do
good luck
rickk
Post Mon Aug 01, 2005 9:39 pm
Except from the oil cooler and ECU, think the easiest way to spot it is the injectors, 325i ones are grey/blueish, 320i items are yellow.
325i block also has a bigger intake system (everything, basically), but this is hard to spot if you can't compare directly. (then it's suddenly pretty obvious)
I figure he has dumped a 325i block in a 320i, if you want to check, the 325i 'shell' should have rear disc brakes (320i too if it's got ABS, but that's rather rare) and the battery in the trunk as opposed to in the engine compartment.
325i also has an anti roll bar at the rear.
Ofcourse, there's also a fair difference in performance :cool:
johnono
Post Mon Aug 01, 2005 10:04 pm
intake mani is the most obvious, unless he put a 20 one on there to style it, which i dont think would even work.
325i engine
320i engine
the 25 is "rounder"
mrLEE30
Post Tue Aug 02, 2005 4:52 am
the 325 also has 2.5 on the block next to the second spark plug, look from above under the spark plug heat shield just above the exhaust manifold.
slideways
Post Tue Aug 02, 2005 6:24 pm
thanks for all your info guys. 10/10 again.
and no smart comments either...wow :D
xedman
Post Tue Aug 02, 2005 7:01 pm
sorry to butt in...
does it only have 2.5 written between the spark plugs? mine has 2.5 over 2.7, are they all like that?
mrLEE30
Post Wed Aug 03, 2005 5:16 am
think they all say 2.5 / 2.7 its because the 2.7 shares the same block but with different con rods etc.
mrlee
