hydraulic handbrake
nm1
Post Wed Apr 29, 2009 9:10 pm
does any1 have them fitted to there cars
i like to drift my sport but my handbrake is crap and all the jap boys have them any advice would be greatly accepted
fuzzy
He who sleeps with "Gingers"
Post Wed Apr 29, 2009 9:11 pm
are they still illegal on road cars? im sure they used to be.
nm1
Post Wed Apr 29, 2009 9:15 pm
excuse my ignorance but why are they illegal?
fuzzy
Post Wed Apr 29, 2009 9:16 pm
ive no idea, im sure i read that they are . i could be wrong.
nm1
Post Wed Apr 29, 2009 9:18 pm
you could be right i have never seen one on a road car before
fuzzy
Post Wed Apr 29, 2009 9:19 pm
a quick look on google says a mechanical handbrake is required for an mot pass.
Elecblondie
Post Wed Apr 29, 2009 9:22 pm
Most road rally cars run with a hydraulic handbrake. You can plumb it in line on the solid brake line to the rear thanks to the front rear split on the e30 :D. As long as you have a mechanical handbrake it's legal.
benjy
Post Wed Apr 29, 2009 9:30 pm
Hydraulic handbrakes are illegal for road use. In case they lose pressure apparently. Hence the mechanical systems :)
Elecblondie is spot on, as long as you have the mechanical one for "on road" use you fine.
HTH
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Benho
Post Wed Apr 29, 2009 10:36 pm
benjy wrote:Hydraulic handbrakes are illegal for road use. In case they lose pressure apparently. Hence the mechanical systems :)
HTH
i wonder how many MOT centres will actually check the handbrake tho. how often do they fail cars on hydraulic handbrakes is what ill like to know
GuyM
Post Wed Apr 29, 2009 10:39 pm
i have one in my track (road legal) car next to the normal handbrake.
you can have it if you like........ if you are any good a rerouting brake pipes....as i want my abs removed so if you are handy with the spanners in the brake dept and can route my pipes direct from the servo you can have the hydralic handbrake (and the abs system if you want it) for free. :)
i am in watford, herts
Elecblondie
Post Wed Apr 29, 2009 10:57 pm
HTH
People in my motor club used to get pulled up on it, they added the hydraulic handbrake by welding in a bracket and connecting a generic master cylinder to the standard lever. They'd then slacken off the cable so it was ineffective. I think people tend to try it on a little less these days, I've not heard of anyone recently putting a car in for test without a mechanically operated handbrake.
luxy
Post Thu Apr 30, 2009 1:32 pm
I also run a hydraulic handbrake on my E30 318is. I have retained the mechanical activation to the 'drum' element of the brake and just cut into the rear brake line fitting the feed side to the handbrake hydraulic cylinder the output from which goes to complete the curcuit, this retains a fairly stock look other than brake cylinder sitting at the end of the handbrake lever and avoids extra levers. I've had no trouble getting it through MOT's and it works well!
Luxy
