Strectched tyres (Shedrool83 - Cliffybabe)
Post Sun Apr 26, 2009 10:35 pm
That is close 8O
40 profile is much better IMO :)
shedrool83
Post Sun Apr 26, 2009 11:02 pm
I did compare a 40 to the 50 and the difference is huge.
Just have to wait until i have spare cash for tyres now :cry:
Post Sun Apr 26, 2009 11:03 pm
I would also get the arches rolled or even flared. That is what i am going to do when i have saved up some money :)
shedrool83
Post Sun Apr 26, 2009 11:15 pm
Agree.
Think it the only way to go so theres no issues at all.
Post Sun Apr 26, 2009 11:24 pm
Plus, you can then get even wider alloys to fit winkeye
Post Sun Apr 26, 2009 11:31 pm
Dan325iSport wrote: I have indeed. I've got 215/40's on 9's all round on my IS and on the rear of my touring. I've done 15k miles in my IS with the stretched tyres without any problems and it doesn't get an easy life either.
End of the day though.. How hard a life can an iS actually give tyres.. winkeye :twisted:
Post Sun Apr 26, 2009 11:54 pm
Dan320is
Post Mon Apr 27, 2009 6:02 pm
:roll:
suchy
True Zone Relic
Post Tue Apr 28, 2009 12:13 am
Bob_S wrote:
suchy wrote:I run 225/45/16's on 9j rears on standard mtec springs/dampers and can't take passengers in the rear (quote??) as they rub my rolled arches. Not stretched too much but enough to look ok without the risk of a blow-out and I get a decent contact patch. Grazing a kerb is a c**t though :(
you appear to have a large offset on the back
Nah pretty sure it's standard ET, the tyres just aren't super stretched, but just enough to clear the arches without rear passengers
rikster
Post Tue Apr 28, 2009 2:39 pm
my rears rub with an arch roll and slight flare with anyone in the back which a set of adjustable dampers will soon sort. the rears are 9x15 with 215 45 15 the fronts are 8x15 with 195 45 15 i think there 45 cant remember might be 40
miniblob
Post Tue Apr 28, 2009 11:32 pm
I love the stretched look personally - on the right car!!!!!
Won't be doing that on my touring though!!
327 Touring with bass!!!
cool_ram_in
Post Wed Apr 29, 2009 12:31 pm
Massive rubbing shedrool83! :?
Try rolling the fenders a bit...
Probably the easiest way...
Are you going back to use stock wheels?
If you do you should consider the lower profile tires...
ps- My 70 profile tires are the original size for my 316, eheheh. Quite amusing on roundabouts! winkeye
As the carbed m10 has only about 75 hp they roll quite nicely! :D
