DME relay location
GrindCulture
Mon Apr 20, 2009 6:55 pm
Quick one as above, my car's suffering from the DME relay symptoms but I don't have any manuals or anything handy to tell me which one it is. It's a 318i touring btw.
Cheers lads. :D
Not in E30s any more :(
GrindCulture
Mon Apr 20, 2009 7:13 pm
Never mind :) :locked:
roley
Mon Apr 20, 2009 7:36 pm
its k7 and the relay is £6.10 plus vat from the stealers bought on last week
sam325is
Mon Apr 20, 2009 8:59 pm
DME for £6.10????
roley
Mon Apr 20, 2009 10:12 pm
thats what the dealer told me its the same as the fuel pump one.and the invoice also confirms this
Tue Apr 21, 2009 12:26 am
K7 is an unloader relay, and is in the fuse box.
Fuel pump relay is under the bulkhead wiring cover, is identical electrically to K7, but has lugs on the case to hold it in place.
DME relay is also under the bulkhead wiring cover, but is a five pin double pole relay, also with securing lugs.
sam325is
Tue Apr 21, 2009 12:40 am
DME relay is not the same as the fuel pump one and costs more in £10-£20 price range
Reflex
Tue Apr 21, 2009 3:17 pm
what does the dme do?
There Was A Time Last Year When I Was 17, But I'm 19 Now... And Things Have Changed
http://photos-h.ak.fbcdn.net/photos-ak- ... 778999.jpg
GrindCulture
Tue Apr 21, 2009 6:24 pm
Just to clarify, the DME relay is closer to the o/s, and the fuel pump in the middle?
Tue Apr 21, 2009 9:23 pm
Not necessarily, as the mounts easily unclip, and they can be put back in any order.
The DME relay has five pins; the fuel pump relay, and lambda sensor heater relay (if fitted) are identical, and have four pins.
The DME relay is switched on by a section of the ECU in response to 12v+ from the ignition switch being applied to it, and applies power to the injectors, the fuel pump relay (but doesn't turn it on), and the rest of the ECU.
GrindCulture
Tue Apr 21, 2009 9:53 pm
Nice one, cheers Brian :thumb:
