Steering coupling splines..
Post Mon Apr 20, 2009 11:55 pm
Does anyone know the number of splines, or specifications/dimension of splines on the e36/46 rack and the e30 steering column?
Post Tue Apr 21, 2009 12:02 am
Column splines are different to rack end, I gave up looking for something that would fit other than the original linkage
E36 column splines are the same as the rack end though
Post Tue Apr 21, 2009 12:19 am
Column isn't the big issue.. I need a smaller lower UJ!
Theo
Post Tue Apr 21, 2009 12:26 am
Jhonno wrote:Column isn't the big issue.. I need a smaller lower UJ!
Pourquoi?
Post Tue Apr 21, 2009 12:27 am
Grinder? :)
Post Tue Apr 21, 2009 12:49 am
Pourquoi?
Column to coupling contact is low on my list of fun things.. 8O
DanThe wrote:Grinder? :)
I may have a go at 're profiling' the standard one :)
Jon_Bmw
Dangerous when thinking
Post Tue Apr 21, 2009 12:53 am
Arn't the BTB manifolds supposed to clear the coupling. :? They start to sound even more expensive, if they can't even manage that 8O
Is it an e36 rack? I still thought they were advertising as clearing them though...
Theo
Post Tue Apr 21, 2009 1:01 am
Jhonno wrote:
Pourquoi?
Personally, I'm quite fond of my steering column being in contact with the steering coupling!
Post Tue Apr 21, 2009 1:07 am
Theo325 wrote:
Jhonno wrote:
Theo325 wrote: Pourquoi?
Ha... Ha
Manifold to coupling.
It catches the lower UJ... If i'd have been going faster the other day I wouldn't have an e30 to drive right now imo..
I am not gonna drive the 'Ring like it is atm, fuck that for a game of spoons
Theo
Post Tue Apr 21, 2009 1:15 am
Poly engine mounts?
Post Tue Apr 21, 2009 1:17 am
AKG Motorsport sell Group N spec rubber ones for 24v swaps.. I am going to invest I think.
Still not comfortable with the gap to the coupling though, so will mod/replace also
Post Tue Apr 21, 2009 1:18 am
Jon_Bmw wrote:Arn't the BTB manifolds supposed to clear the coupling. :? They start to sound even more expensive, if they can't even manage that 8O
They clear.. But its tight, and turns out the engine moves enough on fast/hard left handers, particularly if the arse comes out, to contact and lock up the steering..
baptie0
Post Tue Apr 21, 2009 1:41 am
for the money that the btb costs you would think that this would not happen. :eek:
Post Tue Apr 21, 2009 9:50 am
How close is it?
Post Tue Apr 21, 2009 11:03 am
About 5mm max.. I can't move my engine by hand, but it moves enough to hit it and it has dented the manifold even!
Post Wed Apr 22, 2009 12:59 am
Move the column where it comes through the bulkhead.
Post Wed Apr 22, 2009 1:04 am
How would one go about that? Sounds rather extreme.. 8O
Post Wed Apr 22, 2009 1:27 am
Make up an offset bracket for where it comes through/is bolted to the bulkhead, and a little bit of pedal bending and respacering. Clutch master rod bolts to the other side of the pedal from normal, as well.
Move the standard brake servo outwards in a similar way.
gareth
Post Wed Apr 22, 2009 1:45 am
i've fitted a short section of 1.5"x1.5"x1/4" angle to the top stud of my engine o/s mount, with a cut-down spare engine mount rubber bolted to it - facing the chassis rail. not elegant but there's a mm or so clearance so no extra vibration at idle but when i really lean on it, the rubber on the extra mount pushes against the chassis rail and stops the engine moving any further.
crude but effective and if it means i can make a hard brake/corner if i need to (not just pushing-on but in an emergency) then it's a compromise i'm willing to have. never had any contact since then, even on the 'ring with sticky tyres, bouncing over the kerbs with some force :twisted:
Bob_S
Post Wed Apr 22, 2009 10:15 am
Jhonno, I have some nice poly mounts here.. £25?
They cured the same problem for me until I found a way around it with some butchering
Bollocks to this 24v scrap!
