Guys,im [] this close to fitting a half-decent Sound platform in the car..
for those of you that have beatin me to it did you Dynamat yer CAB??..i know its the best thing to do but im thinking with a CAB is sound deadening the Boot a good idea considering its harder to get the base inside the Car as it is..
If so..did you do the roof conpartment too
suggestions and ideas pls
Have you got a CAB and have ICE installed? ref:*dynamat*
fowler
- Boost Junkie
i diid my apart from the rear seat panel with the dynomat you are stopping sound getting out so iff you do all the othe panels apart from the rear seat panel the sound will fine the easest route through into the cabin
Dont do your roof cabin bit as this will block any bass line coming through pluse it will reduce the space for your roof when its down making more presure o9n the rrof whe its in closed state
mrLEE30
personally only dynamated the front speaker wells and inside the rear quaterpanels leaving just enough room for the rear windows to slide down.
Sounds very good, if you listen carefully it is playing now!!
mrlee
mrlee
HartgeH27
MMMMM Where is Placey ????? He would have constructive answer to this one !!!
