I might have to make up something similar too when I start building a 2.1 so looking forward to seeing how this turns out
Yeah i was a bit, stuck the 1.9 in and had done with it. The 1.9 is a 1998 block, 50k miles, out of an auto etc, and I got it cheap so couldn't say no! Stuck in some new gen bm big end shells (complete waste of time, the origs were basically brand new!) and away I went. I needed some time off I figure. Am ready to go with it again now though! Need to find another block and order some rings! Shouldn't take long to put it all together, she's got long mot (straight through other than sticky brake light switch) and tax, new tyres etc so nothing else needs attention.Dave_M3 wrote:Good to see you still tinkering with the M42s Tim!!!
I thought you were about to give up when you were selling off all the stroker bits a few months ago
the cases are different, both front and rear pieces.rix313 wrote:Did you end up fitting the lower guide inplace of the sproket? What was involved with doing it if so? Just buy the guide and swap it over? or was the timing case different with an extra threaded hole?
nah by some happy circumstance i was way too busy with work commitments and stuff to actually bother selling any of the stuff, and now feel ok with getting it all going again! Worked out pretty well reallyappletree wrote:So did you never sell your old 2.1 set up in the end tim??
sg_frost wrote:I'm now building one of these with a rover 75 diesel crank. Does anyone have any piccies of how to modify the nose?
