how do i get in boot ?
beavere30
Mon Apr 13, 2009 4:10 pm
hi anybody know how i can get in boot without destroying it the doors open n shut with either key or remote but boot stuck shut. n e 1 have n e ideas ?
cheers brett
Bob_S
Mon Apr 13, 2009 6:01 pm
If you insert a cocktail stick into the bootlock, angle it at about 30 degrees upwards the tip will locate in a small hole, lift the stick vertical and then push the key past it, turn the key slightly to the right and then left very quickly, this usually works.
In your dreams boy, 1 post on a forum asking how to get into a locked car.. a ha.
Bollocks to this 24v scrap!
badassyas
Mon Apr 13, 2009 7:29 pm
does the key rotate the boot lock barrel at all?
Dave_M3
Mon Apr 13, 2009 7:38 pm
Bob_S wrote:If you insert a cocktail stick into the bootlock, angle it at about 30 degrees upwards the tip will locate in a small hole, lift the stick vertical and then push the key past it, turn the key slightly to the right and then left very quickly, this usually works.
:rofl:
murran
Mon Apr 13, 2009 8:39 pm
its a specialist tool you need..........
have a read up on it!
http://en.wikipedia.org/wiki/Crowbar_(tool)
winkeye
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
fingerman
Mon Apr 13, 2009 9:41 pm
Obviously not a scouse then :duck:
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
ProToZyKo
Mon Apr 13, 2009 9:54 pm
Think crowbar would break something.
Dave_M3
Tue Apr 14, 2009 12:04 am
ProToZyKo wrote:Think crowbar would break something.
Really!!!
murran
Tue Apr 14, 2009 12:13 am
id post up a link to a tin opener but i cant be arsed!
robbo86
Tue Apr 14, 2009 12:52 am
cheers brett
Pardon!?
allow me
Dave_M3
Tue Apr 14, 2009 2:17 am
You can get into the boot without damaging it...
But you need to be able to get into the car first though :D
mash320i
Tue Apr 14, 2009 5:00 pm
lol genius
