Leonardo Lpg conversion
e301988325i
Post Fri Apr 10, 2009 12:16 pm
Hi, I've bought a leonardo aeb 175 conventional lpg system that is currently fitted to a 2.5L 24V M50 in an E34 1993. I'm going to fit it to my 2.5L 12V M20 1988.
It isn't fitted with a backfire flapwhere can I get one from? Ps) M30 AFM installed.
Why does the gas feed venturi need to be fitted before the AFM?
Does anybody know of any wiring diagrams for the leonardo AEB 175 unit? Although by tracing the original install I've cracked most of it.
There are 3 wires coming out of the leonardo box that have been cut into the BMW M50 ECU, could anybody tell me what the equivalent is on the BMW M20 ECU?
The wires are grey to grey, purple to purple, blue + yellow line to brown + black line.
There are 4 wires contained in one sheath, coming out of the leonardo ECU that I am unable to identify, they are light blue, white, orange, mauve. Can anybody shed any light?
Where is the best place to break the injector common wire and the fuel pump relay feed in my E30 and what colour are these?
Do I need to fit a lambda or is this just for initial setup? The M20 has two downpipes, is one lambda in one pipe acceptable or do I need one in each pipe? Will my E30 have the lambda plug under the battery tray?
Can anybody suggest if the 2j1 I've found here is any good, or is there a cheaper/better alternative? Suggestions on a postcard please.
http://trigger-wheels.com/store/index1. ... FQodNT9iRg
I don't have a laptop to plug into the system to tune it, can anybody help with this after I've done the install?
So many questions!!! Thanks in advance, Alex
I said:
e30topless said:
lock the wife in there
CHR1S1990
Post Fri Apr 10, 2009 12:23 pm
hi mate
if you PM us your email address I'l send you the document for the leonardo kit which includes the wiring diagram and helps a hell of a lot!
CHR1S1990
Post Fri Apr 10, 2009 12:38 pm
As brian previously stated
2/Use the two yellow wires from the Leonardo ECU to cut the feed to the injectors at pin 87 of the main DME (white) relay. This will also disconnect the power to tyhe idle control valve as well, so run a seperate new wire from 87 of the DME relay to pin 2 of the idle control valve in place of the existing one.
This sounds like the wires for the stepper motor, do they not have a plug on the end?
I would put a lambda sensor in - doesnt take long and doesnt cost a lot. I bought a 4 wire one (heated) off ebay posted for under a tenner. Welding one in one of the downpipes theroteically is fine as the gases should have the same properties if im correct? As regard to fitting again from brian:
Two white wires are for the heater. Earth one and feed the other, via a 7.5A fuse from pin 87 of the yellow fuel pump relay. This will then switch the lambda heater on whenever the engine is running (along with the petrol fuel pump).
Grey wire is the lambda signal earth wire, so earth that as well (by a seperate wire). Black is the signal wire, and goes to Leonardo purple
You can get the catflat backfire valves off ebay, or LPG online shops such as http://www.tinleytech.co.uk/acatalog/St ... ping_.html or http://www.lpg-kits.com/ although im not sure of the size of the m30 AFM
The grey from the leonardo is for the lambda sensor, as is the purple. The blue/yellow wire is to be connected to the TPS switch - on the M20 the blue/brown wire (middle wire IIRC)
Chris
e301988325i
Post Fri Apr 10, 2009 12:58 pm
CHR1S1990 wrote: There are 4 wires contained in one sheath, coming out of the leonardo ECU that I am unable to identify, they are light blue, white, orange, mauve. Can anybody shed any light?
Chris
These wires disappear into the ether, the kit is still on the E34. I was not able to see a stepper motor, but this was probably down to my ignorance!!! where would it be located?
There is a black/red feed to the vaporiser triggered by the blue out of the leonardo ECU, which splits off to a solenoid which I assume allows hot water to flow around the vaporiser.
Many thanks, I searched for these answers but only managed to fing general info. and when searching for brianmoooores posts, it wouldn't let me get off of page 1 of the search results!!!
In the current install, the engine bay lpg cutoff solenoid is on the drivers side, the lpg pipe thens runs behind the engine to the vaporiser on the passenger side, is this to add extra heat to the lpg? Should I copy this when installing, or should I have the cut off solenoid close to the vaporiser??
Installation instructions by e-mail.
Many Many thanks! Alex
I said:
CHR1S1990
Post Fri Apr 10, 2009 1:14 pm
the stepper motor is located between the AFM and the vapouriser and there should be a plug on the end of those 4 wires which plugs straight on.
the blue wire from the leonardo supplies a "+12v power output for the alternative fuel electrovalves". This selonoid isnt for water flow but for gas flow. You should have 3 selonoid valves in the system all taking a +ve from that leonardo blue: one on the vapouriser one seperate one and one on the multivalve on the tank.
I wouldnt have thought they have done it to gain extra heat more likely they fed it down the drivers side of the car to steer clear of the exhaust - and no i would not copy this when installing. The passenger side strut is a perfect place for the valve - i ran my copper pipe from the tank (i have a cylinder tank in the boot not torroidal in the spare wheel well) down through the boot, above the diff steering clear of the exhaust at all times (at least 30cm away IIRC) - if this is not possible then a heat shield can be made
Post Fri Apr 10, 2009 2:54 pm
Most questions seem to have already been answered!
You don't need anything remotely like the 2j1 - that's a wideband sensor and controller. All you need is an ordinary 4 wire lambda sensor, and a M18 X 1.5 nut welded onto one of the downpipes to fit it.
I can supply circuit diagrams for two versions of the required laptop cable, copy of the software, and copies of the COP11 installation 'code of practice'.
Any chance of a pic of how the mixer is fitted on the M50? This type of system is not at all normally suitable for a M50, with its plastic manifold, although someone produced a special mixer for these. If it has one, then I'd be interested in buying it from you.
e301988325i
Post Fri Apr 10, 2009 4:51 pm
The mixer is an aluminium ring (80mm od 40mm id approx) which fits inside the 90 degree rubber elbow before the throttle body. It has a feed into it from the side, through the rubber elbow and then lots of 1.5 mm holes drilled radially into the inside of this ring, hence the venturi effect drawing the lpg (propane) vapour through.
Apparently the car has backfired on occasion and blown the icv and other hoses out, these have been secured now and backfires havn't caused any obvious damage, ie the car stills works fine. . .
Ps) I don't have any pics at the moment Brian. When I get the kit (Monday maybe) I will post pics up.
Pps) Won't I be needing the mixer??
Ppps) I'll pm you my email as the more info the better. It's the lack of laptop that's the problem more than a wire. In truth I don't think it would hurt to have someone with some previous experience help set this up as I really don't know what's going on. I'll read the installation instructions today, so maybe it is explained in there.
Thanks again Alex
I said:
e301988325i
Post Fri Apr 10, 2009 5:04 pm
This stepper motor is eluding me, what does it look like, what is it's function?
The vaporiser feeds gas towards this Alumininium ring I've described in the inlet tract with a straightish bit of radiator pipe. It's cramped in there but I wasn't able to anything else non standard around this area, could it be in the airbox although I missed any wires heading there?
Many thanks Alex
I said:
e301988325i
Post Fri Apr 10, 2009 5:27 pm
Have investigated stepper motor. My first thoughts are that this is absent, is this possible, would the system still work, if it is absent do I need to get one, if so which one?
Many thanks Alex
I said:
Post Fri Apr 10, 2009 9:46 pm
The stepper valve looks something like a T shaped idle control valve, as fitted to some 6 pot E30s. Not surprising, as they are essentially the same thing!
Follow the hose from the mixer ring, and you should come to the stepper valve before you reach the vapouriser. If it's not there, then the system was operating as a crude open loop system, and the Leonardo controller was doing absolutely nothing!
The mixer you have won't be of any use to you for a M30, unless 1) there is a piece of hose immediately before the AFM that fits it, OR 2) there is a hose after the AFM, but before the air take off for the idle control valve that fits it, and you fit a device to hold open the flap of the air meter when running on LPG.
gareth
Post Sat Apr 11, 2009 12:19 am
my mixer bolts to the inlet of the AFM, between the AFM body and the round hose adaptor jobbie. i guess with a M30 AFM, you'll need the larger 80mm blowback valve which are harder to come by than the 70mm variant. there is one on ebay at the moment though http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0359996212
if you need a stepper motor, i got one from tinley tech recently for £32.50 + vat which seems fairly reasonable. you may need to see if they can source a connector too though as it's fairly unusual... though i'm sure i've seen them on other cars i've faffed with.
e301988325i
Post Sat Apr 11, 2009 3:05 pm
Ok thanks Gareth, I've been watching the 80mm cat flap I think I'll buy it if they're a bit rarer.
I've asked the seller (guy from work not ebay) to look for the stepper motor, it does seem missing, however the wiring for it is integrated into the E34 somewhere or other, hopefully the plug is still attached and then I'll get a stepper to suit. Glad they're not frighteningly expensive!!!
Do the solenoid filters ever need replacing? if so is it a whole new solenoid assembly or just buy a little filter?
Brian I trust your opinion but can you explain why the mixer needs to be before the AFM, does the lpg vapourt really add that much volume to the air?
edit:- stepper motor is present, just very hidden out of sight!
I'm liking the suggestions to fit the filler behind the number plate on a hinge, has anybody got any pics?
Thanks Again Alex
I said:
Post Sat Apr 11, 2009 8:55 pm
Mixer has to be before the AFM because of the restriction in the flow rate caused by it, which messes up the venturi effect required of the mixer. The alternative, as I posted above, is to use a "flap opener" (basically a small hydraulic ram, operated by the LPG) to open the AFM flap right up.
Filters only need replacing if they're clogged. Most of the rest of the world gets properly formulated autogas, but in this country (surprise!) we get commercial grade propane, which can occasionally have all sorts of undesirables in it, that can block the filters on one tankful.
I've not changed a filter in 100,000 miles of LPG motoring on one E30.
e301988325i
Post Mon Apr 13, 2009 9:45 pm
Hi, bad news the tank doesn't fit the wheel well, it's a 70L 650 X 280mm. I'll have to get one that fits. Can anyone decipher what's stamped on the tank, it means nout to me other than 70L, the pressure and 80%. The spots of rust, is this a problem?
Anyhow this lot for £100 10mins away still isn't bad!
edit: I've finally found the online shop at tinley tech, took me long enough :o:
Thanks Alex
I said:
Post Mon Apr 13, 2009 10:52 pm
67R bit is the standard that the tank has to meet, and the last bit is November 2000; the date it was certified.
A 630mm diameter tank will just fit into an E30 well.
The Leonardo switch fits perfectly into a spare E30 switch position, with a little sliver of plastic cut from a switch blank, at each end, and looks OE.
e301988325i
Post Tue Apr 14, 2009 6:39 pm
Great tip I'll do that with the swith.
Certs have to be done every 10 years IIRC, which pretty much makes my tank scrap?
I'm looking at getting a new single hole toroidal tank from tinley tech for around £150 + postage which seems quite good, 630mm X 225mm, 53L.
Thanks Again
I said:
e301988325i
Post Sat Apr 18, 2009 1:54 pm
I've started sorting out the tangle of wires supplied, and soldered back together what had been cut in the removal, also I've cleaned up the vaporiser which is a landi. . .
I've got the mixer mounted before the AFM, and I've positioned the switch in the dash, not much done but it's started!
Has anyone got any pics of the vaporiser mounted on a 325i, the only place that it seems to fit is under the pas bottle?
With the vaporiser mounted here the first solenoid valve in the engine bay is going to be right next to the vaporiser's inlet solenoid, is this first solenoid needed?
Mixer adaptor
vaporiser
switch
I said:
Post Sat Apr 18, 2009 2:45 pm
The area under the PAS bottle is the place for the vapouriser on an E30. Mines actually on a stud fitted to the chassis rail.
Your mixer arrangement looks ingenious, although the sharp steps in the airflow won't do anything to help power!
It looks like your vapouriser has had a filter solenoid screwed directly on to it. Is there another solenoid on the vapouriser? Top right in the pic?.
It would be best to seperate this and mount the filter up on the top of the suspension turret, beside the PAS bottle.
e301988325i
Post Sat Apr 18, 2009 5:28 pm
White plastic is impossible to photograph, it seems to absorb light, in the direction of airflow the plastic is tapered and radiused to match the inlet dia of the mixer, I could machine the mixer on the exit side to make it a bit smoother but there's only so much time for homework at work!!!
On the E34 there was a solenoid on the multivalve then a solenoid/filter on the driver's side inner wing, then the solenoid/filter (identical) screwed to the inlet of vapouriser, then the blue solenoid on the exit of the vapouriser, all triggered from the blue outlput of the leonardo. So, which of these do I and don't I need??
Also as well as a new tank I'm going to need a new multivalve and level sensor as the new tank will be a lower height, where can I get an AEB one to match the system. Unless you knpw of any tricks Mr.Moore. Ps) how do you drain/ vent the remainder of the LPG in the tank?
Thamks Again! Alex
I said:
Post Sun Apr 19, 2009 12:33 am
Ditch the solenoid/filter that's screwed into the side of the vapouriser.
To empty the tank, take it outside on a day with a least a bit of wind, and power the solenoid from a battery, then leave it until it is completely empty. If you can't power the solenoid for some reason, slacken off the bolts holding the multivalve, a fraction of a turn at a time, until it leaks.
Don't do this near any drains, or low places where vapour may collect, don't make sparks, and don't put your hands near the escaping vapour - it's extremely cold, and will cause frostbite!
The Leonardo system can be configured in the software and by using different configurations of the wiring to suit any type of tank level sensor.
e301988325i
Post Sun Apr 19, 2009 12:13 pm
I thought it seemed like a lot of solenoids!!! Will my car have the lambda control relay, how do I check, and if it doesn't do I just plug a relay in and hey presto?
I'll have to go somewhere quiet to drain the tank, middle of a garage block in my housing estate doesn't seem the best place!!!
Could someone tell me where the 'main' relay is, so I can cut the red and white injector+fuel pump relay+icv feed? And also where is the best location to rerun the icv power to, trying to keep the engine bay looking neat?! My Haynes manual is hopeless here!
Thanks Again
I said:
Post Sun Apr 19, 2009 3:27 pm
You have a Leonardo shown in your pics further up the thread, so I'm assuming you've used it!
Venting the tank in the middle of a housing estate would probably make the national TV news, so I suggest you take it out into the country.
It's perfectly safe with a bit of common sense, as LPG mixture isn't as easy to ignite as you might think.
'Main' relay on a 325 is the white one under the cover by the air meter/filter. There should be two red/whites leading from one of the pins, and you should be able to trace one of them going to the fuel pump relay next door. Cut the other one, to connect in the two yellows from the Leonardo, then run a fresh red/white wire in a black sleeve to the point on the loom where the ICV wires branch off. Dig into the loom, cut through the red/white, and connect your new wire to the half that goes on to the ICV. Connect the other end of your new wire to the remaining red/white and the Leonardo yellow on the 'main' relay.
e301988325i
Post Sun Apr 19, 2009 6:07 pm
Brianmoooore wrote:You have a Leonardo shown in your pics further up the thread, so I'm assuming you've used it!
Sorry, I've not used it before, was supplied to me in bits removed from someone elses car?
Brianmoooore wrote: Venting the tank in the middle of a housing estate would probably make the national TV news, so I suggest you take it out into the country.
:rofl:
Do you know about this lambda relay? I've bought a lambda sensor from ebay to plug directly into the socket beneath the battery tray.
On a seperate note will the petrol ECU actually adjust the mixture from the lambda signal?
Thanks Again
I said:
e301988325i
Post Sun Apr 19, 2009 7:30 pm
Ok, using the motronic wiring diagram, the lambda sensor relay should be next to the fuel pump relay and is of the same type. I've been outside and checked and the wiring and relay socket are in place for this, and my ecu triggers the lambda relay with +12V which makes life easier!
edit: I've been reading this which is quite interesting, mine's the 173 ecu which appears to adjust maps based on lambda input.
http://www.e30tech.com/forum/showthread ... da+control
It looks to me like the ICV/injector red/white wire split underneath the middle of the inlet manifold, although I haven't taken the inlet trunking and AFM off yet for proper access, I've got to wait for the 80mm catflap to arrive first.
I said:
e301988325i
Post Sat Apr 25, 2009 5:33 pm
Ok latest update.
I've exposed the wiring loom in the car now, bolted the leonardo in behind the ABS ECU and planned all the wire runs and joints/splits, doing it this way I'm only going to have 4 seperate new wires in the engine bay, 1) yellow/yellow, 2) coil positive and negative, 3) new ICV feed, 4) Stepper motor lead. which should lead to a tidy install. . .
I'm going to mount the filler under the rear number plate, on pins with R-clips so it can be removed completely and won't get smashed by me being clumsy with come fill up time!!!
I'm still waiting for the cat flap. . .
I've been to an installer who has pointed out that my vapouriser is not E67R01, so with the cost of seal refresh kits I'm going to buy a new one.
OMVL R90E seems the way to go as the others seem to be limited to 190BHP which I'm pushing the threshold of now. . .
Anyway I've left the car at the garage for the MOT and lambda boss fitting this weekend so I'm not making any progress here.
I'm going to be ordering bits and pieces on Monday
This £100 folly is going to end up around £500 albeit with nearly all new parts. . .
I said:
gareth
Post Sat Apr 25, 2009 5:53 pm
i have two used vaporisers here if you're on a tight budget. one slightly crusty OMVL R90/e (was using this myself) and a pretty new looking tartarini unit (looks fine and promised to be fine by the chap i bought it from but untested by me). both have been on 3.5 M30 engines so should be fine for you.
that said, while trying to trace a fault, that turned out to be two clogged solenoids, a clogged filter and a failed oxygen sensor, i did buy a new OMVL R90/e off ebay for £69.50 delivered next day (hency my spare)! can't be a bad investment considering the cost of even a seal kit.
http://cgi.ebay.co.uk/OMVL-R90-High-Pow ... 240%3A1318
e301988325i
Post Sat Apr 25, 2009 7:39 pm
Thanks Gareth, but a second hand one + postage + seal kit is not sensible, I'm going to get that one in the link, thanks it's £30 cheaper than tinley tech and the 90 degree filler from the same seller is £8 less!
The idea was initially to do the conversion for next to nothing but the kit I've bought is so old most of it is scrap apart from the leonardo controller, solenoid valves, multivalve and mixer. looks like the savings will be punished for the real love in my life again!
I said:
Post Sat Apr 25, 2009 7:53 pm
e301988325i wrote:This £100 folly is going to end up around £500 albeit with nearly all new parts. . .
All worth it though, when you stand in line waiting to pay at a fuel station, having filled your tank from empty to brim full, for £25!
gareth
Post Sat Apr 25, 2009 8:48 pm
i do love standing there filling the car when everyone else walk past looking confused as they've not see that wierd pump being used before. sometimes get a "what's that you're filling with?" type of comment, i reply "LPG, 50.9 p/litre" i then either get a lot of interest, or a remark like "lucky git"!!!!
only once have i ever seen someone else fill with LPG and we were both stood there, filling up and out of the blue he said to me "bloody marvelous this isn't it, i f*****g love filling up now" "i feel so smug"
never fails to lift your mood :D
Rodderz
Post Sat Apr 25, 2009 8:54 pm
What are the chances of getting a kit fitted for £500?
johnl320
Post Sat Apr 25, 2009 8:58 pm
I've had this experience for the first time yesterday with jon_bmw's old 318is 27 squid! I couldn't beleive it :D
gareth
Post Sat Apr 25, 2009 9:16 pm
smug-ness associated with saving money on fuel tends to lead to a feeling of euphoria, or that could just be a side effect of the blast of gas!
e301988325i
Post Sun Apr 26, 2009 12:17 am
I'm looking forward to it, but as I live 3/4 mile from work and cycle on the 4 days I do work, it'll take about 300 years to repay the cost of installation!
However, IF I start having to commute anywhere then I won't have to sell my beloved toy and buy a slow, noisy, economical, small, front wheel drive piece of blandness :D
I said:
e301988325i
Post Tue Apr 28, 2009 9:12 pm
Ok a busy day today! Mostly good news too, firsst off my car passed it's MOT, but it's still at the garage awaiting the welding of the lambda bosses.
I've machined the cat flap flap to work properly (was catching internally), and reduced the diameter to acccept the standard E30 belows.
I've ordered a new tank and polyflex tubing fromt tinley tech so that should be here by the end of the week and I'll have a bank holiday weekend to spend on he car!
My new vapouriser and filler assembly arrived today too!
I've bought the OMVL R90-E vapouriser. Can someone advise me about the two adjustment screws on the side of it, one turns freely and has a spring on it, the other is described as extra idle adjustment. . . Is there a benchmark position or should it work straight out of the box??
Thanks Alex
I said:
gareth
Post Tue Apr 28, 2009 11:59 pm
it will probably fire up but then will need tweaking. have a read through this forum, you'll pick up a lot of tips. this thread is mine recently while sorting my problem (started with simple setup!!!!) but there are a few good hints on the setup too. keep an eye out for 'brianm', he seem to be a bit of a know-it-all :D :D :D :D :D winkeye
http://my90.co.uk/lpg/viewtopic.php?t=6 ... 7de1c795ff
this shows how to set it all up via the leonardo http://www.diy-lpg.co.uk/articles/files ... -loop.html
and this shows the principes behind the various adjustments (the 'power valve' being replaced with the leonardo actuator / stepper) http://www.diy-lpg.co.uk/articles/files ... -loop.html
