My E34 iX touring has decided to show low oil pressure light and check-control warning...
I've changed the switch and checked the oil-filter bolt to ensure the rubber o-ring is still in place..
The problem still exists, though...
The engine sounds fine and appears to run OK...when I last drove it (Monday) it worked perfectly without any issues...
Problem is, I need a daily driver.
Do I sell it as-is, fix it then sell it or fix it and keep it or break it for spares?
I hate dilemmas...
Any suggestions?
PS: I suspect that the problem is likely to be either a failed oil pump or drive or a camshaft end-seal
what to do...
Fushion_Julz
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Morat
What engine is it? Surely if its an M50 then swapping for a known-good engine would be the easiest option. You can keep/strip/rebuild your old engine in slowtime if you're kinky that way
Fushion_Julz
I could rebuild it, but at the moment the engine is in good health, no noises and (apparantly) no oil pressure!
If I was going to repair it, I would remove the sump and inspect/replace the oil pump, drive sprocket and pressure relief valve. The most likely cause of failure (if there is a mechanical failure) will be the sprocket drive...
The main issue is it is an iX and therefore requires removal of the offside driveshaft as well as the sump...
I am going to get myself a mechanical pressure gauge and check the pressure for real...
If there is pressure, then the fault is electrical and relatively easily sorted....
If there is no pressure, then I am going to p/ex it with an E36 328i 4dr that is more my sort of thing anyway...
check it with an oil pressure gauge if your not sure and go from there!
AS above, get a gauge on it, or council stylee, whilst running ,loosen the 13mm oil filter housing bolt and see how much oil spews out !
E34 dash clusters are a bit flaky and the oil pressure warning is one i have seen before . Usually low oil level or pressure will be quite obvious in that your tappets will become quite vocal.
