My son has an E-34 525 , 1998
Both lens`s on the driving lamps are cracked (common ?) and whilst we are replacing them, we are going down the HID line as in my E-30.
Has anyone come across BOTH lens`s cracked at the same time ALSO how easy is it to change to HID`s compared to the E-30.
I can source the HID`s , but I really need to buy two drivers lamp units for the "boy" as his wife is about 6 weeks away from having their first kiddie.
This would be a nice weight off his mind guys.
ANY advice is most welcome and "I " will be paying for this.
Thanks alot ,
E-34 and HID`s
StuBeeDoo
On the E-30 Stuart, I had to open up the rear of the bulbholder to take the grommet of the new bulb.I was just wondering if I had to do the same or not.Either way its not a problem.StuBeeDoo wrote:Mart mate, I've never seen E34 lamps, but I assume they're pretty much the same as E30 ones - other than the brackets we've already discussed - so the conversion to HID shouldn't be any more difficult than on your car.
When you say brackets Stuart ,Im not sure where you are talking about mate.
Alpina99
I put HID's in mine & found it very easy,
I'm fairly sure they're exactly the same as E30 units,
I know I'll be putting them in my E30 when it's finished,
Gone, but not forgotten !!
Did you have to open up the rear of the bulb holder to take the large grommet ? and yes they do look so much like the E-30 lamps.Alpina99 wrote:I put HID's in mine & found it very easy,
Ziggy
Exactly the same method as for the E30 - I took mine out of the E30 & put them straight into the E34 with the same bulb holders. Worth noting that bosch bulb holders work on hella lights but not vice versa!
Just as a side note - although the bulb fittings are the same, the mounting points for the lights are not - so you can't use E30 lights on an E34.
Alpina99
Yes, but it wasn't a big job to do,martauto wrote:Did you have to open up the rear of the bulb holder to take the large grommet ? and yes they do look so much like the E-30 lamps.Alpina99 wrote:I put HID's in mine & found it very easy,
georob
a 98 e34?
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
George
